    Disperse trees on terrain
    7 Posts 3 Posters 500 Views 3 Watching
      ryangarnett
      Hello All,
      Does anyone know of a plugin or method to disperse trees over a terrain file? I have build a terrain (from contours) and I would like to add trees to the area. I am using the RP TreeMaker plugin for the trees. I would like to be able to make a tree and then disperse it X number of times over my terrain, ensuring the tree is stamped to the terrain. And I would rather not have to do it by hand, tree by tree.
      Thanks...
        Component Spray?
          ryangarnett
          That might work.
          Thank you....
            ryangarnett
            Is it available for version 8? I have installed the version 7 copy, but it is not working.
              Are you using this...
              http://forums.sketchucation.com/viewtopic.php?t=33908
              ...version?
                Also MakeFur woks fine
                  ryangarnett
                  GAO I just saw that version last nite. I am going to give it a try. The video look really promising. Thanks!
