    Rendering several individual scenes
    renderpluginsextensions
    3 Posts 2 Posters 1.8k Views 2 Watching
      rubenius86
      Hi there,
      I was wondering if it was possible to render several scenes instead of animation with inbetween frames.
      Again I just want to render each scene in "queue/afer one another", without any frames, just one keyframe per scene!
      I hope you understand what I mean!
      Thanks for your help,
      Ruben
      • panixiaP Online
        panixia
        if tou need a batch rendering, go to the "animation settings" in sketchup "enable scene transition" and set the time value to 1s, also set scene delay to 0, then go to the vray animation tab, tick animation on, tick include frame number, tick save to "filename.filetype" as you would do for any animation. now, in the fps tab select "custom" and set the value to 1. now vray will render only 1 frame for every scene.
        i use often this workaround, the only downside i found is that isn't possible using this trick to render separate channes (eg. alpha channel, z-depth, etc..)
        hope this can help.
          rubenius86
          Thanks, this tip really helps me out, now I can render while I´, working...awesome!!!
          Keep it up
          Greetz
