    Make an imported TIF 3D and curved?
    28 Posts 5 Posters 1.2k Views 5 Watching
      Here's a version - try to approximate the length of the arc and gap, size the line to the arc's diameter and bend, scale vertically to height.
      I work x10 larger to avoid tiny facets not forming issues...
      Try it yourself...
      zoe caligraphy oil BENTrescaled+sized.skp
        beemouse
        Perhaps I am not using the right terminology? by depth I meant the distance from the gap to the back of the bracelet (so that it forms an oval and not a circle). The height would be homothétique (I don't know how to say this word in English - the height will be calculated automatically according to the other dimensions given). I will try out your scaling ideas (if I can figure it out), and let you know!!
          You can scale in different axes to make a circle 'oval' - using various green-handles, hold Ctrl to do it center-to-center rather than direct - you can type in various small value changes and watch the selected arcs size change in Entity Info as you do it, till you get near what's needed......
            Roger
            One you have completed the Illustrator course, see: http://www.youtube.com/watch?v=YER82N30vc8 which is part one of a two-part tutorial.
            http://www.azcreative.com
              beemouse
              Well, I started over from scratch, just to get everything correct in my head. You are right Tig, I can't use the exact dimensions I noted, but that is mostly due to the constraints of the 3D printers... I have uploaded and ordered the bracelet. I'll post a picture if it turns out nice!! Thanks for everyone's help! I'll be back soon with questions on how to make layers (ie. a bracelet or pendant with two different layers). Shall surf the forums a bit first though, promise!
                Well done.
                I hope it turns out fine and I'd like to see the result.
                What 'material' have you ordered ?
                  beemouse
                  Thanks! I ordered it in steel for the first go. I won't get it til the beginning of September, but i'll
                  Be sure to post a pic. I hope I got it all right!!
                    I recently got a small stainless-steel puzzle-box made in three pieces, and I was surprised how heavy and 'metallic' it was - they use real metal powder, bound with resins, then the final form is 'tumbled' to polish it, so it comes out just like 'real' s/s...
                    I was very pleased with it.
                    The surface finish will never be shiny smooth, but I think that won't detract from this bracelet's appearance anyway.
                    • 2 / 2
