    Plugin Request - Material Swatch Maker
    3 Posts 2 Posters 363 Views 2 Watching
    • Paul RussamP Offline
      Paul Russam
      On nearly all the models I create I make a swatch of the materials in the model, like this:
      Is there a way to roll this into a plugin? I imagine it would work like so:
      User activates plugin.
      User is prompted for a swatch size - (100mm, 1000mm, 4", 1', or whatever the user types).
      User clicks initial start point.
      Plugin recursively goes through models materials creating swatches 125% of selected size apart (25% gap between each)
      Entire palette of swatches is grouped.
      Possible feature:
      Create text label under swatch of material name.
      Paul Russam
      English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
        I did this already... http://forums.sketchucation.com/viewtopic.php?p=337966#p337966
        You can adjust the code to suit your needs...
          Paul Russam
          duhhh (bangs head off desk)
          Thanks TIG πŸ‘
          Paul Russam
