    Draw on section
    3 Posts 2 Posters 255 Views 2 Watching
    • H
      harnstein
      probably it's been answered somewhere already, i couldn't find it.
      It would be helpful to be able to draw on a section cut, e.g. you design a house and want to add some variation to different levels-
      i normally would export a jpg and draw over it with a tablet, but it would be great to do it directly in SU and then maybe loft these lines..
      If you draw on a section right now it's 1. hardly possible to draw on the section (only from edge to edge) and 2. after drawing the newly created lines dissapear (logically)..
      Any guess?
      still sketchin'
      • TIGT
        Use my 'SectionCutFace' tool to add a grouped set of edges/faces at the cut.
        Then manually change it by editing it and drawing extras...
        • H
          harnstein
          Yep, you're right!
          I should have thought about that.. πŸ˜‰
          I had some troubles with lines lines not showing up and difficulties creating new faces..
          But I just see that there's newer version, i have ver. 2.0 installed..
          -> Installed the new one- works perfectly! Thanks again, where would i be without your (and the other's) plugins!
          Great! πŸ‘
          still sketchin'
