    Thea renders - garden
    36 Posts 18 Posters 3.1k Views 18 Watching
      davidh
      A few more thea renders of a garden with different moods.The first 2 renders are of a model downloaded from Ronen Bekermans site.
      The final image is an NPR of the house in the last 2 renders.
      • N Offline
        ninopiamonte
        I love all of it! β˜€
        • marked001M Offline
          marked001
          Love them all as well... .but that last image is just amazing!
          http://www.revision21vis.com
          instagram: revi21on
          • allanxA Offline
            allanx
            Every render is great, especially the NPR...
            allanx
            Portfolio
            • ely862meE Offline
              ely862me
              Elisei (sketchupper)
              Come and See EliseiDesign
                davidh
                A variation of the foreground planting and a different stream.I also increased the strength of the sunburst.
                • P Offline
                  pibuz
                  David!
                  Those are really masterpieces!
                  I am very curious about how you did the 3D grass and the flowers in the first image: are they modeled by you?
                  WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                    davidh
                    Thanks very much for the compliments.The 3d grasses are from HQ GRASS which are available to buy on line.They really help to create evocotive scenes.
                      cmoreink
                      Is this the website - http://www.3dmentor.ru/index.html if so he has only max and c4d models and no su models. hod did you get yours?
                      my portfolio
                      • david_hD Offline
                        david_h
                        as my Rendering Alter Ego . .I congratulate you ( and therefore myself) on these incredible renders!
                        • masterpaulM Offline
                          masterpaul
                          Pleae do a tutorial or something like that. You would be my hero.
                          • pbacotP Offline
                            Look all through this subforum: http://forums.sketchucation.com/viewforum.php?f=351&start=0
                            Instigated by David himself. Yep, he's a hero.
                            • Rich O BrienR Online
                              πŸ˜†
                              • boofredlayB Offline
                                boofredlay
                                Brilliant as usual. πŸ‘
                                  davidh
                                  Cmoreink,I converted thru 3d max to .obj and brought them that way into Thea.You can download a full working 30 days version of 3dmax which will allow you do the same.
                                    cmoreink
                                    Just like I thought πŸ˜‰ great images Dadvidh. Since you can't bring .max to SU and you bring them as .obj, do you loose any detail in those models?
                                    Would like to see how the last image NPR was composed.
                                    Thanks for your time.
                                    cheers
                                    my portfolio
                                      davidh
                                      The .obj models are brought into Thea and not into Sketchup.
                                      Before you export the models from 3d max you need to ensure that all the materials are standard max materials which means changing them from the vray materials which the models originally have ,otherwise all parts of the models will come through with the same texture.
                                      Once the models are in Thea I add translucency and bump maps and then save them out so they can be used as components/instantces.
                                      Once this is done I open the house Sketchup model in Thea and simply drag and drop the plants.
                                      I have attached 3 more variations of the NPR with different foregrounds and some colour tone revisions.
                                      • david_hD Offline
                                        david_h
                                        truly incredible. . .
                                        (So I am guessing that NPR in this situation doesnt refer to National Public Radio???) πŸ’š
                                        • jo-keJ Offline
                                          jo-ke
                                          I'm speechless. Absolutely perfect
                                          http://www.zz7.de
                                            davidh
                                            Heres a night time version using the technique I uploaded to the post processing forum a while back.I added a few fireflies to the right to add some bright colour.
                                            • 1 / 2
