    Thea renders - garden
    36 Posts 18 Posters 3.6k Views 18 Watching
    • N Offline
      ninopiamonte
      I love all of it! β˜€
      • marked001M Offline
        marked001
        Love them all as well... .but that last image is just amazing!
        http://www.revision21vis.com
        instagram: revi21on
        • allanxA Offline
          allanx
          Every render is great, especially the NPR...
          allanx
          Portfolio
          • ely862meE Offline
            ely862me
            Elisei (sketchupper)
            Come and See EliseiDesign
              davidh
              A variation of the foreground planting and a different stream.I also increased the strength of the sunburst.
                pibuz
                David!
                Those are really masterpieces!
                I am very curious about how you did the 3D grass and the flowers in the first image: are they modeled by you?
                WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                  davidh
                  Thanks very much for the compliments.The 3d grasses are from HQ GRASS which are available to buy on line.They really help to create evocotive scenes.
                    cmoreink
                    Is this the website - http://www.3dmentor.ru/index.html if so he has only max and c4d models and no su models. hod did you get yours?
                    my portfolio
                    • david_hD Offline
                      david_h
                      as my Rendering Alter Ego . .I congratulate you ( and therefore myself) on these incredible renders!
                      • masterpaulM Offline
                        masterpaul
                        Pleae do a tutorial or something like that. You would be my hero.
                        • pbacotP Offline
                          Look all through this subforum: http://forums.sketchucation.com/viewforum.php?f=351&start=0
                          Instigated by David himself. Yep, he's a hero.
                            πŸ˜†
                            • boofredlayB Offline
                              boofredlay
                              Brilliant as usual. πŸ‘
                                davidh
                                Cmoreink,I converted thru 3d max to .obj and brought them that way into Thea.You can download a full working 30 days version of 3dmax which will allow you do the same.
                                  cmoreink
                                  Just like I thought πŸ˜‰ great images Dadvidh. Since you can't bring .max to SU and you bring them as .obj, do you loose any detail in those models?
                                  Would like to see how the last image NPR was composed.
                                  Thanks for your time.
                                  cheers
                                  my portfolio
                                    davidh
                                    The .obj models are brought into Thea and not into Sketchup.
                                    Before you export the models from 3d max you need to ensure that all the materials are standard max materials which means changing them from the vray materials which the models originally have ,otherwise all parts of the models will come through with the same texture.
                                    Once the models are in Thea I add translucency and bump maps and then save them out so they can be used as components/instantces.
                                    Once this is done I open the house Sketchup model in Thea and simply drag and drop the plants.
                                    I have attached 3 more variations of the NPR with different foregrounds and some colour tone revisions.
                                    • david_hD Offline
                                      david_h
                                      truly incredible. . .
                                      (So I am guessing that NPR in this situation doesnt refer to National Public Radio???) πŸ’š
                                      • jo-keJ Offline
                                        jo-ke
                                        I'm speechless. Absolutely perfect
                                        http://www.zz7.de
                                          davidh
                                          Heres a night time version using the technique I uploaded to the post processing forum a while back.I added a few fireflies to the right to add some bright colour.
                                            cmoreink
                                            I use vray ans SU, so I would have to bring the models straight to SU. I tried to import them to SU after exporting from 3ds max as .3ds since SU doesn't read .obj files, but no luck 😞.
                                            Or maybe I'm just doing something wrong? I have also tried bringing them as .dwg or .dxf and it's no go either 😞
                                            Does any one have an idea on how to do that?
                                            thanks in advance
                                            cheers
                                            my portfolio
