    Vray Render color Change
    renderpluginsextensions
    2 Posts 2 Posters 2.9k Views 2 Watching
      ccs1987
      Good Morning everyone.
      At first i was rendering my vray interior scene with only rectangular lights which is only warm colour with normal brightness, the outcome was good where i override every material with white colour. But when i disable override all material. my new render ambiance environment colour became redish. Though it is not finished render, but the red dots all around the map make me nervous because the render will definately take up 3 or 4 hours because it's with great details.
      Any suggestion what happened?
      Ops! the 2nd try, rendering was running fine.
      PS : I don't have much redish reflective materials that would probably change the whole thing to red. But since the 2nd rendering is fine. I still hope for experts to share their experience when come across this problem once a while. Thanks
      Sketchup 8 pro
      Vray
      Intel Xeon W3520 2.67Ghz
      12Gb Ram
      Nvdia Quadro FX 1800
      • V Offline
        valerostudio
        Did you have a red material in your model? I would say that you can never really trust an override render to give you a true idea of your lighting in your final because light will be bounced off of materials and change the tones in your image. For example, a red floor would give off a bunch of redish light (unless you override it in the materials GI).
