    Curviloft and curvemaker.
    3 Posts 3 Posters 243 Views 3 Watching
    • L
      laugeo
      Drawing parabola for use with curviloft?
      Curviloft doesn't work with the parabolas I construct with curvemaker?
      Any suggestions would be welcomed?
      Thanks, Colin.
      If man was clever enough to understand his own mind, he would be so simple that he couldn't.
      • TIGT
        Can you post a simple example and explanation of what you are trying to do...
          If you have Install the Bezier SPline by Fredo 6
          I believe you must make: Right click on the curve of CurveMaker / Change the nature of the curve ! πŸ˜‰
          And then use the Curviloft
