    Understanding Sketchup
    3 Posts 3 Posters 245 Views 3 Watching
    • P
      pmx
      Before using Sketchup for architectural works I would like to understand something about modification of a componant.
      For example, if I create a vase using the "Follow Me" tool, is it possible to modify the curves of it after ?
      The example is simple and the answer could be : "Just draw another one" but I'm thinking about more complex objects.
      If not how peple do to "adjust" their creation ?
      Thx.
        You can scale, rotate and move loops, edges and faces afterwards but it can be a destructive result unless properly planned.
        SketchUp is not like a NURBS package but there are plugins , Artisan and FFD , that allow further tweaks with better control.
        If I had a simple vase that needed tweaking then the scale tool would best best to increase/decrease size.
        • KrisidiousK
          Krisidious
          If you use a plugin like profile builder, then you'll be able to edit follow me paths afterwards.
          http://forums.sketchucation.com/viewtopic.php?t=44237
          By: Kristoff Rand
