    Directly apply a material
    4 Posts 3 Posters 312 Views 3 Watching
      rossthompson
      I am working on a script that activates the paint bucket tool with a predefined material of a certain colour and transparency. The code I have written works fine except on every use it creates a copy of the material eg. 'window1', 'window2' etc. which makes a bit of a mess of the materials palette.
      I think it just needs a simple if statement to avoid creating the material if it already exists. Does anyone know how to do this?
      Thanks Ross
      toolbar = UI;;Toolbar.new "Window"
           cmd = UI;;Command.new("Test") { window }
           cmd.small_icon = "CBG/window_sm.png"
           cmd.large_icon = "CBG/window.png"
           cmd.tooltip = "Paint Window"
           toolbar = toolbar.add_item cmd
           toolbar.show
      def window
       model = Sketchup.active_model
       materials = model.materials
       m = materials.add "Window"	 					# Adds a material to the "in-use" material pallet.
      m.color = Sketchup;;Color.new(100, 150, 240)	# Specify the colour
      color = m.color
      alpha = m.alpha=0.5								# Set transparency
      materials.current = materials["Window"]			# Set to the current material
      Sketchup.send_action "selectPaintTool;"			# Start the paint tool
      • TIGT Online
        Try something like this:
        m=materials.add("Window") unless m=materials["Window"]
        Which sets ' m' to be an existing material named 'Window', but if it fails [ unless or should you prefer it use if not]... then it sets it to a new material named 'Window' [ add]...
          rossthompson
          Hi, that worked perfectly
          Thanks TIG
            Can also be written like so:
            m = materials['Door'] || materials.add('Door')
