    Texture help
    15 Posts 5 Posters 1.1k Views 5 Watching
    • N Offline
      Nikola Pavic
      👊 i need help about the textures.I make my model or however u call it and its made out of multiple groups and i dont know how to add textures in .png format.I want it to be like this:
      http://www.epicminecraft.com/wp-content/uploads/2010/10/minecraft-skin-editor.jpg
      a image including every face of the component and that i edit that image in png format.So do i need any plugin to save and use textures in .png format and,when i press the "edit textured image" button it opens the image in ACDsee and i want to open it in a different image editing software.
      so please help. 😢
      thanks. 😄
        Under Window menu > Preferences > Applications, you can set your preferred image editor in SU. I am not sure if I understand the first part of your post though...
        • N Offline
          Nikola Pavic
          I want to make pixel textures so its small,really small texture image.So i want the image for the texture to be in .png format so every pixel on the image could be seen clearly not blured like .jpeg format that the SU creates,and i meant is there a way that just one image could be a texture image for multiple surfaces that are together. (like on the image above)One image where there is multimple surfaces/sides that it covers.
          can u understand now? 😕
          • numbthumbN Offline
            numbthumb
            The closest thing would be to unwrap it in an external app IMO.
            Or, on a "boxy" model like that, you could try Jim Foltz´s Unfold: http://sketchuptips.blogspot.com/2007/08/plugin-unfoldrb.html
            Comfortably numb...
            • N Offline
              Nikola Pavic
              i have tried the unfolt tool and thanks for the link but thats not what i wanted.I want for it to look like this:
              http://i1190.photobucket.com/albums/z441/Nikola_Pavic/polligon1.png
              this is how it looks,on the left is the model and on the right is the texture image.
              http://i1190.photobucket.com/albums/z441/Nikola_Pavic/polligon2.png
              and this is what i want to do.Every texture image is for the entire component,so this is how i want to be in SU,so is it posible? to be similar like this?
              • iichiversiiI Offline
                iichiversii
                Ummm you know what, I would like to know this also, it would be great if you could texturise your model in SU with multiple textures and have it unwrap all the textures onto 1 textile, or 2 if maybe, I wonder is there a plugin to do this with complex geometry, Im not sure if it can be done directly in SU but I'm sure it can be done in an external uv wrapper, maybe some1 could enlighten us, and what is the best freeware uv mapper capable of doing this?
                Bring on the Rain...
                  numbthumb
                  UV Import/Export bridge to external UV mapping software - and that would mean UVTools, or even better, SketchUV.
                  As Whaat said: ...almost any app that can import and export OBJ files:
                  http://forums.sketchucation.com/viewtopic.php?f=323&t=23725&hilit=UVTools
                  Comfortably numb...
                    iichiversii
                    I must purchase this sketchuv, a lot swear by it, what are your opinions on roadkill uv mapper?
                      numbthumb
                      I by no means consider myself an UV mapping expert, but I´m quite satisfied with it for the time being.
                      One thing I like about it is that the UV view updates automatically with every cut. Of course, that is probably something that doesn´t apply specifically to Roadkill, but I haven´t spent too much time exploring other apps.
                      Althought that ALT+mouse stuff for navigating is a bit frustrating.
                      Comfortably numb...
                        iichiversii
                        Cheers numbthumb, 👍
                        • N Offline
                          Nikola Pavic
                          YES! Thats exactely what i waned! thank u so much! 💚 ...but...which one of this is good? and what do u get with payed that isnt in free? 😕
                            numbthumb
                            So give it a try and see if it suit your needs.
                            I guess all of them are good enough, depending on the usage of the user. The free stuff works just fine for someone who´s just getting into UV editing.
                            Comfortably numb...
                              ArcTec
                              cant you use projected textures?
                                iichiversii
                                Doesn't always work on complicated geometry
                                  ArcTec
                                  Here's a link btw http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94883
                                  Was going to edit my post but had to wait for it to be approved by moderator.
