    Texture help
    15 Posts 5 Posters 1.3k Views 5 Watching
    • iichiversiiI
      iichiversii
      Ummm you know what, I would like to know this also, it would be great if you could texturise your model in SU with multiple textures and have it unwrap all the textures onto 1 textile, or 2 if maybe, I wonder is there a plugin to do this with complex geometry, Im not sure if it can be done directly in SU but I'm sure it can be done in an external uv wrapper, maybe some1 could enlighten us, and what is the best freeware uv mapper capable of doing this?
      Bring on the Rain...
      • numbthumbN
        numbthumb
        UV Import/Export bridge to external UV mapping software - and that would mean UVTools, or even better, SketchUV.
        As Whaat said: ...almost any app that can import and export OBJ files:
        http://forums.sketchucation.com/viewtopic.php?f=323&t=23725&hilit=UVTools
        Comfortably numb...
        • iichiversiiI
          iichiversii
          I must purchase this sketchuv, a lot swear by it, what are your opinions on roadkill uv mapper?
          • numbthumbN
            numbthumb
            I by no means consider myself an UV mapping expert, but I´m quite satisfied with it for the time being.
            One thing I like about it is that the UV view updates automatically with every cut. Of course, that is probably something that doesn´t apply specifically to Roadkill, but I haven´t spent too much time exploring other apps.
            Althought that ALT+mouse stuff for navigating is a bit frustrating.
            Comfortably numb...
            • iichiversiiI
              iichiversii
              Cheers numbthumb, 👍
              • N
                Nikola Pavic
                YES! Thats exactely what i waned! thank u so much! 💚 ...but...which one of this is good? and what do u get with payed that isnt in free? 😕
                • numbthumbN
                  numbthumb
                  So give it a try and see if it suit your needs.
                  I guess all of them are good enough, depending on the usage of the user. The free stuff works just fine for someone who´s just getting into UV editing.
                  Comfortably numb...
                    ArcTec
                    cant you use projected textures?
                    • iichiversiiI
                      iichiversii
                      Doesn't always work on complicated geometry
                        ArcTec
                        Here's a link btw http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94883
                        Was going to edit my post but had to wait for it to be approved by moderator.
