    Texture help
    15 Posts 5 Posters 1.3k Views 5 Watching
    • numbthumbN
      numbthumb
      @nikola pavic said:
      i meant is there a way that just one image could be a texture image for multiple surfaces that are together. (like on the image above)
      The closest thing would be to unwrap it in an external app IMO.
      Or, on a "boxy" model like that, you could try Jim Foltz´s Unfold: http://sketchuptips.blogspot.com/2007/08/plugin-unfoldrb.html
      Comfortably numb...
      • N
        Nikola Pavic
        i have tried the unfolt tool and thanks for the link but thats not what i wanted.I want for it to look like this:
        http://i1190.photobucket.com/albums/z441/Nikola_Pavic/polligon1.png
        this is how it looks,on the left is the model and on the right is the texture image.
        http://i1190.photobucket.com/albums/z441/Nikola_Pavic/polligon2.png
        and this is what i want to do.Every texture image is for the entire component,so this is how i want to be in SU,so is it posible? to be similar like this?
        • iichiversiiI
          iichiversii
          Ummm you know what, I would like to know this also, it would be great if you could texturise your model in SU with multiple textures and have it unwrap all the textures onto 1 textile, or 2 if maybe, I wonder is there a plugin to do this with complex geometry, Im not sure if it can be done directly in SU but I'm sure it can be done in an external uv wrapper, maybe some1 could enlighten us, and what is the best freeware uv mapper capable of doing this?
          Bring on the Rain...
          • numbthumbN
            numbthumb
            UV Import/Export bridge to external UV mapping software - and that would mean UVTools, or even better, SketchUV.
            As Whaat said: ...almost any app that can import and export OBJ files:
            http://forums.sketchucation.com/viewtopic.php?f=323&t=23725&hilit=UVTools
            Comfortably numb...
            • iichiversiiI
              iichiversii
              I must purchase this sketchuv, a lot swear by it, what are your opinions on roadkill uv mapper?
              • numbthumbN
                numbthumb
                I by no means consider myself an UV mapping expert, but I´m quite satisfied with it for the time being.
                One thing I like about it is that the UV view updates automatically with every cut. Of course, that is probably something that doesn´t apply specifically to Roadkill, but I haven´t spent too much time exploring other apps.
                Althought that ALT+mouse stuff for navigating is a bit frustrating.
                Comfortably numb...
                • iichiversiiI
                  iichiversii
                  Cheers numbthumb, 👍
                  • N
                    Nikola Pavic
                    YES! Thats exactely what i waned! thank u so much! 💚 ...but...which one of this is good? and what do u get with payed that isnt in free? 😕
                    • numbthumbN
                      numbthumb
                      So give it a try and see if it suit your needs.
                      I guess all of them are good enough, depending on the usage of the user. The free stuff works just fine for someone who´s just getting into UV editing.
                      Comfortably numb...
                        ArcTec
                        cant you use projected textures?
                        • iichiversiiI
                          iichiversii
                          Doesn't always work on complicated geometry
                            ArcTec
                            Here's a link btw http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94883
                            Was going to edit my post but had to wait for it to be approved by moderator.
