    Minimum wall thickness?
    3 Posts 2 Posters 647 Views 2 Watching
      RBarone
      Anyone know of a plugin that highlights a preset minimum wall thickness for 3d printing?
      For example if i set a minimum wall thickness to 3mm it would check the model and point out anything less than the minimum?
      I am getting pretty good at Sketchup and have downloaded many plugins already. But maybe Sketchup do it already and I am just not seeing it?
        I Xray mode you can see the inside and outside of a solid object's "shell".
        You can then pick points with the TapeMeasure tool and get the distance == thickness...
        Also cutting sections lets you see inside objects and do similar measuring...
          RBarone
          Thanks TIG. Much appreciated.
