    Rotating opposite doors
    14 Posts 5 Posters 593 Views 5 Watching
      Rose123
      hi all,
      i'm trying to rotate the bookcase doors so they open opposite each other, as shown in this video. however, the doors rotate the same direction, as if they are stuck to each other. they are components, and i did flip one of the components -i know i flipped it successfully because when i edit one door, the same edits show up on the other door, in a mirrored location. so why can't i open them opposite each other with the rotate tool, as shown in the video?
      thanks for any insight.
        The guy has made a copy move on the Green axe
        the made a right click / Flip along Gren Axe on the copy component ๐Ÿ˜‰
        So now you can edit any component and you will have the same result than the video ๐Ÿ˜‰
          Rose123
          Pilou -thanks ...but i DID copy and then flip. And like I said, when I edit one door, the other edits as mirror, so that at least works. But I can't get them to rotate opposite each other. They stick together in the middle and rotate the same direction.
            Have you flip along the direction of your copy move ? Use the function right click Flip along !
            Red for a red move
            Green for a green move
            Blue for a blue move!
            Here a green ๐Ÿ˜‰
            There is absolutly no problem! Edit any of them that works fine as wished ๐Ÿ˜„
            diagonal_copy.skp
              Rose123
              hi pilou, thanks for the file, but i'm trying to understand why mine won't work. here's a screenshot of what it does. i want the doors to open OPPOSITE each other, like in that video.
              http://s83.photobucket.com/albums/j320/DrawMeAPicture/?action=view&current=Untitled.png
                Seems they are "Pasted"
                You must have just one selected, and double click on just one for edit it !
                here you have all selected!
                And post your images (upload attachment)
                on the forum, your host server have some troubles and generates alert advices! ๐Ÿ˜ฎ
                Post the file skp (Save as V6)
                  It appears to me that you've got what is referred to as a nested group or component of the two doors. This means that the two doors are wrapped together and when you click on one with the Select tool you are actually selecting both of them. I don't know why you'd want the two doors nested together but if you do, double click on the nest to open it for editing. then select one door at a time and rotate it open. Personally I would just explode the nest so the two doors are separated. Let them be components or groups on their own.
                  By the way, the interior of your case appears to need a little attention. Or is the bottom supposed to be sloped to the back?
                  Edited to add: If your doors aren't groups or components on their own, they'll be stuck together and you won't be able to open just one. Make sure you have made a component of one door and copied it.
                    Rose123
                    They're not nested together. I've redone this multiple times ...I make one door a component, copy it, flip it, move it back... I can select and rotate each door individually, and they rotate correctly, but not together.
                    re the case, yes, i probably did mess it up during one my umpteen redos.
                    • pbacotP Offline
                      Are you doing the rotation on the objects inside one of the components? That would cause the objects in the other (mirrored) component to rotate in a mirrored direction. Rotating a component that is NOT "open" or in edit mode does not affect other components. It looks like you were rotating two "closed" components.
                        Rose123
                        Oh, that's the secret! No, I had just selected them; I didn't put them in edit mode.
                        So I put one in "edit component" mode, selected it in its entirety, then rotated. Yep, they both opened opposite each other. Thanks!
                          Rose123
                          BTW, it doesn't seem like I have a file uploading option. Do you have to have a certain # of posts before you can do that?
                            Maybe yes but not absolutly sure
                            A moderator will say that ๐Ÿ˜‰
                            About your problem : i had written that as soon as my first post! ๐Ÿ˜‰
                            So now you can edit any component!
                              You're well over the required number of posts to be able to upload attachments. Make sure after you Chose the file you click the 'Add the file button'.
                                New members have a bit of limitations (first couple of posts moderated) but nothing with attachments so you should be able to upload even with the very first post.
