    Materials can't be removed
    3 Posts 2 Posters 279 Views 2 Watching
    • B
      bulbangs
      I have a problem that's driving me absolutely nuts.
      Every model I open has these four materials
      http://i.imgur.com/ltzlM.png
      I've used the purge ruby and they are deleted. I've also opened model info and used the purge button there and they likewise go away.
      When I reopen sketchup, they're back.
      I've tried purging then saving as template, without the materials present in model and when i save and reopen sketchup they're back again.
      Can anyone assist me in how to remove these annoying materials.
      I suspect the source of these materials was one model I downloaded from 3dwarehouse.
      I tried reinstalling sketchup and it got removed. However when I open one of the models i'm working on, they're back in their immortal state.
      I can't re-do the models i'm working on since they're already too complex and I need them for work. I need a solution that purges these materials permanently from any model i'm already working on.
      • massimoM
        massimo Moderator
        I think they come with the ivy generator plugin. You can try to remove it and see what happens.
        • B
          bulbangs
          OMG.
          They were part of the ivy plugin!!!
          Thanks so much massimo!!
          I guess I'll have to keep the Ivy plugin out until i use it next.
          I think i lost some braincells trying to remove those materials!!!
