    How to make it pls
    28 Posts 6 Posters 928 Views 6 Watching
      The profile needs to be aligned on the radius of the circular path.
      Start with the circular path centered on the origin and the rectangular face on a radius of the circle. I delete the face of the circle before running Follow Me because if you don't, there'll be no face created on the bottom of the extrusion.
      Thanks, Mike.
      • E Offline
        erzane
        I succeeded it
        but I didn't needed to erase the basis circle
        I just choosed the follow me tool and pushed ''Alt''
        http://img708.imageshack.us/img708/1589/capture01oy.jpg
        thanks for your help 😉
          Glad you got it to work.
          Now correct the face orientation so the back faces (blue) are inside and delete the circle for the path and you're finished.
          • E Offline
            erzane
            done
            now I would like to place it on the center of the circle but I dont know how to center it..
            http://img824.imageshack.us/img824/2113/capture01qi.jpg
              Probably the easiest way would be to add some temporary cross hairs at the bottom center of the thing. Then grab the thing at the center with the Move tool and move it to the center of that other circle. It would be best if you make that shape a component and change its axes so they are centered at its bottom center. then bring the component in from the Component browser. See this for reference.
              • E Offline
                erzane
                ok I see, this is the famous glue I learned last year
                I forget all about what I learned last year, it's terrific lol
                anyway during your reply I do it like this
                I erased the circle and created a new one from the basis with the offset tool
                http://img805.imageshack.us/img805/773/capture01r.jpg
                  Good. Now correct the face orientation. Don't be sloppy in your modeling. 😉
                    Where did you read that, Pilou? I don't see that anywhere in his original post.
                    You right for the text 😉
                    I had interpreted the images! And was right! 😉
                    And sure your method is more speedy than the FredoScale when you start from the beginning! 😉
                    But when you have yet the object, that is an another story! 😄
                    • 2 / 2
