    Snap fail
    8 Posts 4 Posters 631 Views 4 Watching
      metaclay
      I got this model grabbed from 3d warehouse, this is a simple piece of street/road (i attach the skechup file). This is weird i can't even snap to any of its corner/vertex. Anything wrong with the model ? i have no problem in snapping to other normal model/object. What is wrong ?
      Thanx
      no_snap.skp
        Its edges are hidden so you have nothing to snap to. Either turn on hidden geometry (View menu) or unhide them (edit the group, triple click, right click somewhere and "Unhide").
        • srxS Offline
          srx
          It could be a style without edges.
          www.saurus.rs
            metaclay
            Thanx Gai and Srx, problem solved. Btw, i got more question, when snapping between obj , how to force snap while the point/face is not co-plannar , i means they're on different plane, it only snap when they're on the same plane. Can i just snap to any point regardless they're position in 3d space ?
            Thanx
              It could also be - but here this was not the case (Susan had all her edges).
              Yes, you can, so if you have problems, please post specific examples.
                metaclay
                Here's simple setup, i create 2 rectangles, one is lying on ground plane (xy plane) while another is above the ground ( i moved it vertically along z axis). I tried to move any vertex of rectangle#1 to snap to any point of rectangle#2. How to do it ? Right now, it can't snap to other rectangle coz they're on different plane.
                Thanx
                • pbacotP Offline
                  Thanx
                  You are right it can't. That's because SU is trying to help by preventing you from warping your rectangle (see below). I guess the question is what are you trying to end up with in the model? You can obtain "inferences" from points on edges (e.g. endpoints) of the upper rectangle, if you are trying to align the lower point directly below it. You have to do that in a couple of steps (I can give if you need) but the easiest thing is to project edges down from the upper rectangle to the lower rectangle plane, so you can snap to the endpoints.
                  Generally the "snap" to point in this two-plane scenario would only make sense in reference to the camera position--if it worked, if I am understanding correctly. However if your objective is to warp the lower rectangle to a point outside its plane, you have to press command (alt on a PC) to "autofold" the face of the rectangle while moving the vertex.
                    metaclay
                    @pbacot said:
                    Thanx
                    Thanx Pbacot, That makes sense why i can't snap directly to it, yeah it will 'bend' the face. Btw I've just solved it using 'inferences' method like u said.
                    Additional note or request : it would be great if SU got option to turn this on/off , in same 'wild' case, maybe i need to build some free form design, this is also helpfull if i can have option to turn snap on/off , just for flexibility reason (so accomodate more users need). Right now the 'snap-persistent' mode make SU more 'mechanical/technical' but maybe that what the SU is designed for. 😄 peace...
                    Thanx a lot.
