    How to insert components by guide points (point clouds)?
    3 Posts 2 Posters 586 Views 2 Watching
      rulyfauzi
      hello everyone,
      i am desperate in locating lots of components on an exact points imported by points cloud (points from station total in format: x,y,z). Practically i want to put several different components (eg. bone, stone, pollen) on their exact position (xyz). i have tried to work by layers, several csv files, and group the points. But the problem is the points only look different by its color. For advance presentation, i want to change groups of points by components such as i have mentioned above.
      Is there anybody know the sollution of this issue?
      regards,
      ruly fauzi
        Let's assume you have the objects imported into a SKP as components with logically placed axes/insertion points [and with NO instances!].
        Let's assume you have a set of points in a CSV file and you import them into this 'empty' SKP.
        Ensure Layer0 is the active layer.
        Select them and make a group.
        Name the group after the objects the points will eventually represent.
        Put the group on a new layer [also named after the object] and switch it off.
        Repeat for other CSV files/objects.
        Now you have a set of grouped points logically named on their own layers.
        Switch all layers back on.
        Use the Outliner to enter the edit context of a group.
        Select all to pick the points and run this one-liner in the Ruby console to add a component instance at each point.
        m=Sketchup.active_model;a=m.active_entities;m.selection.each{|p|next unless p.is_a?(Sketchup;;ConstructionPoint);a.add_instance(m.definitions["COMPO"],Geom;;Transformation.new(p.position))}
        where COMPO is replaced with the desired component-definition's real name inside ""...
        An instance of the specified component is placed at each point.
        You can always clear the guides after you have used them all.
          rulyfauzi
          Super! Thanks a lot Tig, i have also found out that the plugin guide tools (insert components at Cpoint) is so helpfull. But it seems your method is more simple.
          thanks,
