    Organic and curvy facade
    Scheduled Pinned Locked Moved Organic Modelling
    17 Posts 5 Posters 12.7k Views 5 Watching
      ccs1987
      Good morning everyone,
      http://www.designboom.com/cms/images/ridcue/helpme01.jpg
      i was wondering about the facade that i am going to build according to this picture.I want to get similar facade skin that is in the picture. How should i do it ? I was thinking of making out a a curvy vertical skin along the 4 side of the building, then i will use plugin that i can draw lines on curvy face and then take away the intersected holes between the lines. After that extrude it.
      I have artisan installed too.
      or should use http://forums.sketchucation.com/viewtopic.php?p=217663#p217663 extrude edges plugin?
      Sketchup 8 pro
      Vray
      Intel Xeon W3520 2.67Ghz
      12Gb Ram
      Nvdia Quadro FX 1800
      • DareDevilD Offline
        DareDevil
        Hello,
        This facade is flat with curvy lines... My way to produce this kind of net will use Illustrator before SU.
        In Illustrator, make a regular weaving and distort it. Export it in DXF or DWG and import in SU. Then just extrude it.
          Illustrator if you have some money πŸ’š
          Seems Inskcape for that can make the same for free πŸ˜‰
          And if you want the best ergonomy in 2D take Moment of Inspiration! β˜€
          The demo infinite (without save) is sufficient here
          Make a snapshot of the screen as PNG with transparence! πŸ˜‰
          And use the tricky plugin of TIG Trimer image for pushpull the image! πŸ˜‰
          • brookefoxB Offline
            brookefox
            Not going the image way, how to do this (in a way appropriate to this thread, that is)? How to distort a grid of faces and edges, before or after extrusion?
            faced grid.skp
            ~ Brooke
              Look the gride, it's a funny optic effect!
              See at each intersection : a point appears and disapears successivelly! β˜€
                brookefox
                Lay a smaller grid on it, intersect and warp with what tool?
                ~ Brooke
                • pbacotP Offline
                  You have to "do the warp" in illustrator or another application. IDK if there's a feasible way in SU.
                  Actually I ran a test with a Gimp png image and TIG's Image trimmer. Not sure if it can be made smooth enough (either by the plugin's simplification or more detailed import). Perhaps multiple images must be imported and trimmed. If this is a ramen bar, mine looked like crispy noodles.
                    DareDevil
                    You can use SketchyFFD (Free Form Deformation). I tried it first for this question, but it's too much for my computer... The Illustrator way is very very lighter !
                    • pbacotP Offline
                      I think it is more appropriate to draw the mesh and not necessarily warp it. It doesn't need to be processed by the computer. The artist can draw the shapes required. It would be better in a freehand application, rather than SU with its omnipresent inferencing. The only issue I find is you have to do the nasty DXF or DWG import and make all the faces behave. I drew it in my CAD, created polygons of all the holes and imported that. I think the OP implies the lattice-like facade is also deformed perpendicular to the building perimeter. IDK.
                      I attempted with bezier curves and Lattice Maker and did not succeed. LM placed the offsets every which way and never completed. So if you do it all natively in SU how would you make the offsets?
                      • pbacotP Offline
                        πŸ‘ A tool I've never used 😳 Looks great! πŸ‘
                          Bezier Curves By Fredo6
                          Use the Didier Bur Projection Tools
                          The last tool permits to make a sort of "Flat Offset" with Vector direction
                          Make 2 CleanUP for the Intersections πŸ€“
                          If you want some crazzy no orthogonal sections use successivelly "Projection" with Vector direction
                          and draw the last segment on the first! β˜€
                            Another possibilities πŸ˜„
                            Lattice-izer by Tig
                            http://forums.sketchucation.com/download/file.php?id=28261&t=1
                            http://forums.sketchucation.com/download/file.php?id=28262&mode=view
                            "City Steet generator" by Thomthom
                            http://forums.sketchucation.com/download/file.php?id=42058&t=1
                            http://forums.sketchucation.com/download/file.php?id=42039
                              You have also Doubleline again by Didier Bur β˜€
                              Advantage extremities are perpendicular with the last segment! πŸ€“
                              Clean Up by Thomthom
                                brookefox
                                Looking good to me. Very nice, Pilou. I'm going to take the opportunity to encourage someone to get in touch with Sketchy FFD, as per daredevil's rec... It seemingly would allow manipulation so that the grid remained more faithful to the original, rather than being really a non-grid.
                                Well, I tried it on the simple grid and crashed twice, which is enough for me.
                                ~ Brooke
                                  ccs1987
                                  Hi Guys, let's say that when you look at the plan of the building. The wall i wanted to be curvy. from the picture it might seem to be a straight wall just with pattern on the wall
                                  Sketchup 8 pro
                                  Vray
                                  12Gb Ram
                                    You can curve it!
                                    With Shape Bender by Chris Fullmer or Fredo Scale by Fredo6 πŸ˜‰
                                    Here Shape Bender : Arc can be any curve
                                    The straight line must be parallal to the red Axis!
                                    Wall must be a group or component
                                    and then twisted with Fredo Scale πŸ˜‰
                                    etc...
                                      ccs1987
                                      simply amazing...
                                      Sketchup 8 pro
                                      Vray
                                      12Gb Ram
