    Organic and curvy facade
    Scheduled Pinned Locked Moved Organic Modelling
    17 Posts 5 Posters 13.2k Views 5 Watching
      Illustrator if you have some money πŸ’š
      Seems Inskcape for that can make the same for free πŸ˜‰
      And if you want the best ergonomy in 2D take Moment of Inspiration! β˜€
      The demo infinite (without save) is sufficient here
      Make a snapshot of the screen as PNG with transparence! πŸ˜‰
      And use the tricky plugin of TIG Trimer image for pushpull the image! πŸ˜‰
      • brookefoxB
        brookefox
        Not going the image way, how to do this (in a way appropriate to this thread, that is)? How to distort a grid of faces and edges, before or after extrusion?
        faced grid.skp
        ~ Brooke
          Look the gride, it's a funny optic effect!
          See at each intersection : a point appears and disapears successivelly! β˜€
          • brookefoxB
            brookefox
            Lay a smaller grid on it, intersect and warp with what tool?
            ~ Brooke
            • pbacotP
              You have to "do the warp" in illustrator or another application. IDK if there's a feasible way in SU.
              Actually I ran a test with a Gimp png image and TIG's Image trimmer. Not sure if it can be made smooth enough (either by the plugin's simplification or more detailed import). Perhaps multiple images must be imported and trimmed. If this is a ramen bar, mine looked like crispy noodles.
              • DareDevilD
                DareDevil
                You can use SketchyFFD (Free Form Deformation). I tried it first for this question, but it's too much for my computer... The Illustrator way is very very lighter !
                • pbacotP
                  I think it is more appropriate to draw the mesh and not necessarily warp it. It doesn't need to be processed by the computer. The artist can draw the shapes required. It would be better in a freehand application, rather than SU with its omnipresent inferencing. The only issue I find is you have to do the nasty DXF or DWG import and make all the faces behave. I drew it in my CAD, created polygons of all the holes and imported that. I think the OP implies the lattice-like facade is also deformed perpendicular to the building perimeter. IDK.
                  I attempted with bezier curves and Lattice Maker and did not succeed. LM placed the offsets every which way and never completed. So if you do it all natively in SU how would you make the offsets?
                  • pbacotP
                    πŸ‘ A tool I've never used 😳 Looks great! πŸ‘
                      Bezier Curves By Fredo6
                      Use the Didier Bur Projection Tools
                      The last tool permits to make a sort of "Flat Offset" with Vector direction
                      Make 2 CleanUP for the Intersections πŸ€“
                      If you want some crazzy no orthogonal sections use successivelly "Projection" with Vector direction
                      and draw the last segment on the first! β˜€
                        Another possibilities πŸ˜„
                        Lattice-izer by Tig
                        http://forums.sketchucation.com/download/file.php?id=28261&t=1
                        http://forums.sketchucation.com/download/file.php?id=28262&mode=view
                        "City Steet generator" by Thomthom
                        http://forums.sketchucation.com/download/file.php?id=42058&t=1
                        http://forums.sketchucation.com/download/file.php?id=42039
                          You have also Doubleline again by Didier Bur β˜€
                          Advantage extremities are perpendicular with the last segment! πŸ€“
                          Clean Up by Thomthom
                          • brookefoxB
                            brookefox
                            Looking good to me. Very nice, Pilou. I'm going to take the opportunity to encourage someone to get in touch with Sketchy FFD, as per daredevil's rec... It seemingly would allow manipulation so that the grid remained more faithful to the original, rather than being really a non-grid.
                            Well, I tried it on the simple grid and crashed twice, which is enough for me.
                            ~ Brooke
                            • C
                              ccs1987
                              Hi Guys, let's say that when you look at the plan of the building. The wall i wanted to be curvy. from the picture it might seem to be a straight wall just with pattern on the wall
                              Sketchup 8 pro
                              Vray
                              Intel Xeon W3520 2.67Ghz
                              12Gb Ram
                              Nvdia Quadro FX 1800
                                You can curve it!
                                With Shape Bender by Chris Fullmer or Fredo Scale by Fredo6 πŸ˜‰
                                Here Shape Bender : Arc can be any curve
                                The straight line must be parallal to the red Axis!
                                Wall must be a group or component
                                and then twisted with Fredo Scale πŸ˜‰
                                etc...
                                • C
                                  ccs1987
                                  simply amazing...
                                  Sketchup 8 pro
                                  Vray
                                  12Gb Ram
