    Bug import files .3ds
    16 Posts 5 Posters 986 Views 5 Watching
    • sketcpeppe75S Offline
      sketcpeppe75
      because importing a .3ds files into sketchup (free models at the official site furnishings RODA) I have problems with the surfaces? as a tool I can use to create the faces rapidly? Open the file with 3dsmax shows no errors.
        sketcpeppe75
        I noticed the same problem with the models free of archive3d.net
        in this case the object is decomposed. I'm confused 😲
          sketcpeppe75
          This is as it should be
          πŸ˜†
            Check the scale you import it at. There type of issues are usually a result of very small faces. Change the import scale - then you can scale down the component instance to the correct size.
              sketcpeppe75
              Thanks thanks thanks thomthom you're really nice
              oops ... I'm a little donkey 😳 because I am not a programmer ... just an architect / consumer....non know what an instance.
              However, I solved by setting km.as the unit of mm I had this.
              without too many questions ... I will try to study a little bit .... πŸ˜‰
              What can you tell me the ecliptic broken? modeling just bad? πŸ˜‰
              tanks
                sketcpeppe75
                can not be true ... it is no coincidence! DEDON lounge chair volcano ...
                because I divide them? 😲
                • G Offline
                  garystan
                  thomthom :
                             As I imported a 3DS file into Sketchup (version 7.1),  I too noticed  "triangulation".    I tried scaling it,  but that didn't work.
                              The files I downnloaded from 3D Warehouse seem okay.  They are  .skp files.    The only problem with 3D Warehouse, is that all the  3D people look like zombies, with their arms stretched out.
                  There's no 3D figures walking or riding a bike.....etc...\
        garystan
                    Have a look at the people at formfont.com - not a free service, but they are clean models ready to use without much fuss. Well worth it.
                    • michaliszissiouM Offline
                      michaliszissiou
                      Someone will confirm that 3ds import id broken under SU 8 all updates? Under OSX 10.6.8.
                      SU 7 is still working fine.
                        3ds import works find under Windows, SU8.
                          michaliszissiou
                          Thanks thomthom
                          Try something heavier close the limit (64k single mesh)
                          As I mentioned, I can still import via SU7
                            I've imported large revit models converted to 3ds with no problem.
                              michaliszissiou
                              OK,
                              the problem started on my mac after the first update of SU8.
                              • K Offline
                                kmiglioo
                                i hava a simmillar problem, when impoting 3ds files from max to sketchup. is there a quick way to clean it up?
                                  What problem? Several issues has been mentioned here...
                                  • K Offline
                                    kmiglioo
                                    Sorry the one with missing triangles and re scaling doesn't fix it,also when I export 3ds files from max to Sketchup some weird triangles show up.I've tried several plugins but nothing helps. It would be awesome if someone knows a way to solve it, other than manually. Thanks!
