    Plugin req: last value shortcut
    4 Posts 3 Posters 362 Views 3 Watching
    • tridemT Offline
      tridem
      A very simple request...I guess
      I use SU mainly to draw industrial plants.
      Often I need to move/pull/scale a lot of items for the same value, natively there is kinda snap to the last entered value but sometime it's a long distance and other snaps interfere, it would be easiest having a key that returns that last value
        Unfortunately, as far as I know there is no API access to the last used values for PushPull etc 😒
        • massimoM Offline
          massimo Moderator
          For PushPull you can simply use the tool with a value and then by double clicking on other surfaces the same value will be kept.
          • tridemT Offline
            tridem
            😞 thanks anyway
