    Help with Selection Toys
    10 Posts 3 Posters 683 Views 3 Watching
      sketchitbrk
      Can anybody help me out with this message:
      Error Loading File tt_selection_toys.rb
      no such file to load -- TT_Lib/core.rb
      Can seem to find this file online?
      • massimoM Offline
        massimo Moderator
        Have you installed also the TT_Lib1.2.0?
          That's the one. When posting you are more likely to get the attention of the developer quicker if you post in the thread the plugin was posted. Not everyone monitor the whole plugin section.
            sketchitbrk
            I have only TT_LIB in my plug in folder will try and load your seuggestion
              sketchitbrk
              No Luck with the new download. How do you tell which version you have the labels are the sam TT_LIB and thats it
                How did you install it? Can you post screenshots? Within the TT_Lib folder, is there a set of .rb files?
                  sketchitbrk
                  Cant get a screen shot keyboard isnt responding. There is a whole list of rubys in the folder, 19 in total included is the core.rb that sketchup asks for each time I open it.
                  TT_Lib/core.rb
                  The directories go:
                  PLUGINS/TT_LIB/TT_LIB/core.rb
                  Is the problem here in the directories?
                    Yes, it should be PLUGINS/TT_LIB/core.rb.
                    The error message you got was a clue to where it should be:
                    In my newer plugins I've included more verbose description of the plugin footprints, but this one was so old that it didn't.
                    To aid in installing plugins you can use this utility installer plugin I made: http://forums.sketchucation.com/viewtopic.php?t=42315
                    That should avoid most installation errors.
                      sketchitbrk
                      Thank you Thank you it all works great now. Awesome ruby for landscape design. I got a tutorial from Daniel Tal on it's use. Great work.
                      Thanks Bruce
                        πŸ‘ πŸ‘
