    What plugins to get?
    7 Posts 4 Posters 1.3k Views 4 Watching
    • N Offline
      Nikola Pavic
      ummm...i dont have a single clue about plugins πŸ˜’ ,so what are the basic plugins? like for making sferes,softening edges and othe usefull nad helpfull plugins...so
      please give me links to them πŸŽ‰
      • TIGT Online
        All the creation/modification methods you have listed are already easily achieved by using the native-tools - perhaps you need to check those out vis the Sketchup>Help[F1] tool πŸ˜•
        There's a big red button above this post called 'Plugins Index' - this might give you the clue on how you might find links to all of the plugins available here [and also some hosted elsewhere too...]
        • brookefoxB Offline
          brookefox
          Here's the latest on your list:
          πŸ€“
          ~ Brooke
            Ah yes! 😲
            It's because its on the French Part ! 😳
            corrected in filling my post πŸ˜„
              Indispensables β˜€
              Extrude Line http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=1523 by Didier Bur
              Joint Push Pull http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=6708 By Fredo6
              SmartPushPull http://forums.sketchucation.com/viewtopic.php?f=323&t=23341 by a4chitect
              Tools on surface http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=11212 By Fredo6
              Bezier http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=13563&st=0&sk=t&sd=a&hilit=bezier By Fredo6
              Extrude edges toolsExtrude tools by TIG
              CurviLoft By Fredo 6 😎
              FredoScaleFree Scale Bend by Fredo6
              Shape Bender By Chris Fullmer
              Component StringerBy Chris Fullmer
              Cleanup by Thomthom
              Mirror http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=11532&p=80373 by Frank Wiesner/TIG
              Grow (Multiple Copy Move rot size in same time! ) http://www.crai.archi.fr/RubyLibraryDepot/Ruby/EM/Grow.rb by Tig
              Inverse Selection http://www.crai.archi.fr/RubyLibraryDepot/Ruby/EM/InvertSelection.rb by Tig
              Extrude along a path http://www.crai.archi.fr/RubyLibraryDepot/Ruby/EM/ExtrudeAlongPath.rb by Tig
              Double Line (Walls) http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=12853 Didier Bur
              Weld curves (or lines) http://www.crai.archi.fr/RubyLibraryDepot/Ruby/fr_weld.rb by Rick Wilson
              Projections by Didier Bur http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=960&st=0&sk=t&sd=a&hilit=projection+didier+bur
              FFD Box of deformation http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=6029 by CPhillips
              Clean coplanar surface (inside this plug Skin) http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=6912 by architectboy
              Follow me and rotate http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=13014&st=0&sk=t&sd=a by wikii
              Follow me and keep
              http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=16465&st=0&sk=t&sd=a&hilit=follow+rotate#p129504 by Wikii
              Taper, curve maker http://www.drawmetal.com/home by Draw Metal
              Animation http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=10946&st=0&sk=t&sd=a by Morisdov
              Chris Fullmer http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17358&p=139011#p138625
              Selection Toys by Thomthom
              Subdive and Smoth (basic free) http://www.smustard.com/script/Subdivide by Ricks Wilson
              not free http://www.smustard.com/script/SubdivideAndSmooth by Whaat
              Funny
              SketchyPhysics http://www.sketchucation.com/forums/scf/viewtopic.php?f=61&t=17324&st=0&sk=t&sd=a&hilit=SketchyPhysics#p138266 by CPhillips
              Protrude by Jim Folz http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=13095&st=0&sk=t&sd=a&hilit=protrude#p95818
              Zorro2 http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=16038&st=0&sk=t&sd=a&hilit=zorro2#p124862 by Whaat
              Soap Skin Bubble & Tensile structures (free) http://www.tensile-structures.de/help.html by Josef Leibinger
              Ferrari
                More easy for you than register on the French part! πŸ˜‰
                  brookefox
                  You cheater!
                  The Frenchman edited his post...I swear! He'll not get away with this. I swear!!!
                  And then you went and snuck in that explanation.... I guess that makes it alright.
                  You forgive me?
                  ~ Brooke
