    Vray 1.49.01 (64bits)
    renderpluginsextensions
    5 Posts 4 Posters 4.3k Views 4 Watching
      antlab1977
      Somebody knows were i can find vray 1.49.01 (64bits)...thanks a lot
        Here it says the "current version is 01.49.01". I guess it does not matter if it is 32 or 64 because SU itself is 32 only and V-ray will run under SU anyway although the site says "V-Ray for SketchUp does run as a 32-bit application on 64bit machines and OS's" (whatever that means).
          antlab1977
          thanks a lot for your help,
          its pitty because whe wont use the computer to its full capabilities using vfsu.
          Best Regards,
          • andybotA Offline
            andybot
            @antlab1977 said:
            no such thing. SU is limited to 32 bits, so are all plugins.
            • V Offline
              valerostudio
              There has been a little bit of a discussion from Chaos that they are considering moving the plug-in to an environment outside of SU in order to take advantage of 64 bit. The rumor is that Trimble has no plans of taking SU out of its 32 bit confines anytime soon.
