    Looking for work-around for Scale Tool
    4 Posts 2 Posters 212 Views 2 Watching
      brianedwarddavis
      I've been using SU for years but I am new to this forum. My question is this...is there a way to scale a component (distort/shrink/stretch) in a similar way that you can with a simple cube. For example: After making a cube (before selcting all faces of the cube and creating a component) you can select the top face a then scale this 2d portion to create a four-sided taper/pseudo pyramid. Please understand, I'm not trying to create a simple pyramid but only using the above as an example. What I have is a table base made from various components. The entire table base has been converted into a component. What I am trying to accomplish is to distort/shrink/stretch only a particular face (top) of the grouped component. The scaling tool allows many options but does not allow me this particular editting function. Is there a work around? Any help or suggestions would be greatly appreciated.
        Have you looked at FredoScale? Make sure you read the first post in the thread and get the supporting files and instructions as well.
          brianedwarddavis
          Is this perhaps this script written by the notorious Fredo? I recently was successful in using his Bezier Splines Script. Absolutely amazing!
          Thanks Dave R for this lead! I let you know and post a reply once I have installed and tested the script. By the way, is there a good central location where scripts and plug-ins are located for download?
            Yes it is the script written by the notorious Fredo.
            You can find an index to the Plugins available here by clicking the appropriate red button at the top of the page.
