    Smoothing in sketchup
    5 Posts 3 Posters 979 Views 3 Watching
      Dylly
      Hi guys,
      I mostly use SketchUp to make models and sets for my animations, Yet whenever I import a model into my software from sketchUp I get creases and odd triangles all over the place. Now I believe this to be smoothing related, as if I import the model into 3ds max and apply smoothing most disappear. However I wondering if there is a method of sorting out the smoothing groups in SketchUp itself?
      Thanks in anticipation Tim
        Hi Tim,
        What format are you exporting from SketchUp?
        • rodrigonotorR Offline
          rodrigonotor
          You can use Artisan http://forums.sketchucation.com/viewtopic.php?t=34868
          Take a look
          • Sketchando.net • www.arqcad.net •
            Dylly
            Hi Guys,
            Thanks for the replies. At the minute I'm just importing the SketchUp file into 3ds Max, however what I want to be able to do is export fairly simple models from SketchUp in .ase format. Even importing into Max and apply a smooth modifier I'm still getting the odd crease and wrinkle.
            I have artisan sat in my tool box...I have to admit I never thought about using it...I will give it a try.
              You can try to set welding verices in the 3ds export options dialog but that means you cannot export UV co-ordinates then.
