Lengthening a series of lines in equal increments
@Jeff
Shadowline on the ground of the Curvishear is very elegant!(middle drawing image)
Not possible to make a curve with it ? (maybe a script is yet existing ? )
@Jeff
Shadowline on the ground of the Curvyshear is very elegant!(middle drawing image)
hmm.. not that i know of.. would be neat if you could though..
(actually, you could probably project the geometry somehow?? i think there might even be a plugin that could do it?)
[off:aznqnqp7]
@unknownuser said:@unknownuser said:
@Jeff
- set sun directly overhead to be used as a preview..
- orient the helix to your liking using the shadow as a guide..
- sandbox-> drape…
[/off:aznqnqp7]
So that was simple!
I will try that because seems too simple for to be true!About the first problem
I am waiting the Sdmitch autorization
for calculate a serie of lines not in equal increment -
@Jeff
I'm very bored for testing your genious trick!Very Curious I can't have the open of the all menu of a Shadow settings box dialog!
I don't have the same Shadow settings
From your Shadows settings image
And this don't open something more!(V6 or V7)
Shadow tool is enable on the Toolsbar list menu!Seems i had this box dialog in the past
No more in Style / Edges
The button Activate Shadow dialog seems makes nothing!
No more in selecting curve right click
No more Entity Info, Model info... Cast Shadows, Receive Shadows are enableMaybe I miss something
or a plug squize this function ?
So for the lines in not equal alignement
make each lines as component (see follow how do make that)
(there are the Target)redraw the same number of lines in equal alignement
use any method above for modify them
make each these new lines as a components (there are the Source)
(see follow how do make that)use this tricky new plugin of Sdmitch who permit now replace components Source--> Target
Randomly or Not ! So choose NoSee this post for precision of the normal use of the Replace Components
And maybe a plug(s) for make each (original lines / new lines) a component
Select a familly of lines
Loose geometry to groups by Chris Fullmer
Then Groups to components TT by ThomthomThat all!
hmm.. i don't know what to tell you.. it's not a plugin.. just standard sketchup settings.
does someone with windows know about this?
once you get that part figure out, you'll also want to go Model Info -> Geo Location -> Set Manual Location
then set the latitude to 0º
this will make it possible to have the sun directly over head.. then adjust the time of day settings to fine tune it..
(use Top View when lining it up) -
it's not a plugin.
Of course that is not a plugin, it's just a dialog box
But I have tested that is not a plugin who blocks this Menu function!
Maybe a file has desapearedOr maybe that is a "Pro version" function ?
Docs
From the Doc@unknownuser said:
Activate the Shadow Settings dialog box from the Window menu.
Made but no Box dialog appears!
I will try on V8 tomorrow -
another approach:
(Jim) DrawHelix:
http://forums.sketchucation.com/viewtopic.php?t=33139(TIG) Extrude Edges by Object to Vector to Object:
http://forums.sketchucation.com/viewtopic.php?t=37515download the ExtrudeEdges suite here:
http://forums.sketchucation.com/viewtopic.php?p=217663#p217663 -
@Jeff
on an other computer with V 6,7,8 free your tricky tip works like a charm!So I believe problem should maybe about open "Shadows dialog box" for mysterious reasons!
@davecon said:
Thanks for the help so far everyone
I have got the hang of doing this on a straight line, now the complex bit is trying to do it on a spiral. Currently I am trying to turn the model on the left (spiral with even length lines) in the model on the right (spiral with lines increasing by XX per length)
[attachment=1:2ramdbm4]<!-- ia1 -->spiral lines.jpg<!-- ia1 -->[/attachment:2ramdbm4]Ideally what I would like to be able to do is select the first line (red) and then the last line (green) and be able to input something like "starting the with the first line make all the others increase in XXmm increments"
Here is the file itself so far.
[attachment=0:2ramdbm4]<!-- ia0 -->spiral lines.skp<!-- ia0 -->[/attachment:2ramdbm4]Instead of going to the trouble of creating the equal length lines then extending them incrementally, I would make the "baseline", be it a flat spiral or a straight line divided into the desired number of segments, into a curve using weld and then you can create the lines originating from the curve's vertices.
The code to do this is as simple as this
mod = Sketchup.active_model ent = mod.entities sel = mod.selection if !sel.empty? && sel.first.curve vers=sel.first.curve.vertices # d is initial length, i is the increment, and a is the direction vector d=875.0.mm;i=87.5.mm;a=[0,0,-1] for v in vers p=v.position;pp=p.offset(a,d) ent.add_line(p,pp) d += i end else UI.messagebox "select a curve" end
It would be a monumental task to try to figure out the order of the equal length lines. When you select a group of anything, there is no guaranty that Sketchup will add them to the selection in the proper order. At least that has been my experience.
