    Hole plugin
    18 Posts 3 Posters 1.3k Views 3 Watching
    • N
      njeremy2
      Hello !
      I need some help on a plugin.
      http://img406.imageshack.us/img406/8141/capture2aw.png
      I made geometrical form on that cube and I have a plugin which allow you to make hole in there (pushpull method).
      When I started with 1,2,3,4 then A it worked.
      If I start with a letter then number I have a hole only on A or B, but not in number because the pushpull make a hole on the edge of the cube.
      Why it worked like that ?
      I take the idea from that plugin, but this plugin work only for rectangle form...
      http://rhin.crai.archi.fr/rld/plugin_details.php?id=326
      I modify it to work with one click on the face. (you have to draw the geometrical form first then select the face and it create the hole)
      How can I upload to plugin to show you ?
      File test of Hole plugin
      THX thomthom !
      To use it, copy it into plugin directory.
      Then create a simple cube with geometrical form on that cube.
      Click on "Plugins> njeremy2 Hole"
      The plugin is activated, select the geometrical form and it create the hole
      • thomthomT
        • N
          njeremy2
          I have an another pb... I can't create hole in components or groups. I have to explode it before make a hole
          • thomthomT
            Sounds like you are not referring to the correct entities collection.
            If you use model.active_entities then it'll create the entities in the currently open group/component. If you want to edit a group you need to reference it's Entities collection: group.entities - When editing a ComponentInstance you need to modify the definition componentinstance.definition.entities.
            (Here's a short summary about how instances and definitions relate in SketchUp: http://www.thomthom.net/thoughts/2012/02/definitions-and-instances-in-sketchup/ )
            • thomthomT
              Regarding test_hole.rb
              Your method def in_face is outside the class. Move it to the inside of the class so it doesn't pollute the global namespace.
              @entities = @model.entities
              This is your problem with not being able to edit groups/components.
              model.entities always refer to the root entities collection. Use model.active_entities to the current open set of entities.
              (Still looking)
              • N
                njeremy2
                I'm gonna read your articles
                and test what you tell me to do. ๐Ÿ˜„
                • thomthomT
                  <span class="syntaxdefault"><br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#We&nbsp;get&nbsp;all&nbsp;faces,&nbsp;norms,&nbsp;reversed&nbsp;norms&nbsp;and&nbsp;plans<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">all_faces&nbsp;</span><span class="syntaxkeyword">=&nbsp;[]<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">all_norms&nbsp;</span><span class="syntaxkeyword">=&nbsp;[]<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">all_norms_reverse&nbsp;</span><span class="syntaxkeyword">=&nbsp;[]<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">all_plans&nbsp;</span><span class="syntaxkeyword">=&nbsp;[]<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">j&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">0<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each&nbsp;</span><span class="syntaxkeyword">do&nbsp;|</span><span class="syntaxdefault">current_ent</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if&nbsp;</span><span class="syntaxdefault">current_ent</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">all_faces</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">j</span><span class="syntaxkeyword">]&nbsp;=&nbsp;</span><span class="syntaxdefault">current_ent<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;all_norms</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">j</span><span class="syntaxkeyword">]&nbsp;=&nbsp;</span><span class="syntaxdefault">current_ent</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">normal<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;all_norms_reverse</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">j</span><span class="syntaxkeyword">]&nbsp;=&nbsp;</span><span class="syntaxdefault">current_ent</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">normal</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">reverse</span><span class="syntaxkeyword">!<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">all_plans</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">j</span><span class="syntaxkeyword">]&nbsp;=&nbsp;</span><span class="syntaxdefault">current_ent</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">plane<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;j&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">j&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxdefault">1<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;</span><span class="syntaxcomment">#&nbsp;end&nbsp;if&nbsp;current_ent&nbsp;is_a&nbsp;face<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#end&nbsp;current_ent<br />&nbsp;</span><span class="syntaxdefault"></span>
                  First of all, @entities is incorrect. In your code you set this to @model.entities - which is the root entities collection. The face you pick might be from any group or component - so you want to use the entities collection that face belongs to. face.parent.entities.
                  Second of all, you use a counter to insert items into your arrays.
                  <span class="syntaxdefault"><br />j&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">0<br /></span><span class="syntaxkeyword">for&nbsp;</span><span class="syntaxdefault">e&nbsp;in&nbsp;model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities<br />&nbsp;&nbsp;array1</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">]&nbsp;=&nbsp;</span><span class="syntaxdefault">foo<br />&nbsp;&nbsp;array2</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">]&nbsp;=&nbsp;</span><span class="syntaxdefault">bar<br />end<br /></span>
                  No need for that, just push the data directly to the arrays.
                  <span class="syntaxdefault"><br /></span><span class="syntaxkeyword">for&nbsp;</span><span class="syntaxdefault">e&nbsp;in&nbsp;model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities<br />&nbsp;&nbsp;array1&nbsp;</span><span class="syntaxkeyword"><<&nbsp;</span><span class="syntaxdefault">foo<br />&nbsp;&nbsp;array2&nbsp;</span><span class="syntaxkeyword"><<&nbsp;</span><span class="syntaxdefault">bar<br />end<br /></span>
                  Both foo and bar are still located with the same index in each their arrays.
                  A cleaned up version of your code snippet:
                  <span class="syntaxdefault"><br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#We&nbsp;get&nbsp;all&nbsp;faces,&nbsp;norms,&nbsp;reversed&nbsp;norms&nbsp;and&nbsp;plans<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">all_faces&nbsp;</span><span class="syntaxkeyword">=&nbsp;[]<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">all_norms&nbsp;</span><span class="syntaxkeyword">=&nbsp;[]<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">all_norms_reverse&nbsp;</span><span class="syntaxkeyword">=&nbsp;[]<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">all_plans&nbsp;</span><span class="syntaxkeyword">=&nbsp;[]<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">parent</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each&nbsp;</span><span class="syntaxkeyword">do&nbsp;|</span><span class="syntaxdefault">current_ent</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if&nbsp;</span><span class="syntaxdefault">current_ent</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">all_faces&nbsp;</span><span class="syntaxkeyword"><<&nbsp;</span><span class="syntaxdefault">current_ent<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;all_norms&nbsp;</span><span class="syntaxkeyword"><<&nbsp;</span><span class="syntaxdefault">current_ent</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">normal<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;all_norms_reverse&nbsp;</span><span class="syntaxkeyword"><<&nbsp;</span><span class="syntaxdefault">current_ent</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">normal</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">reverse</span><span class="syntaxkeyword">!<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">all_plans&nbsp;</span><span class="syntaxkeyword"><<&nbsp;</span><span class="syntaxdefault">current_ent</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">plane<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;</span><span class="syntaxcomment">#&nbsp;end&nbsp;if&nbsp;current_ent&nbsp;is_a&nbsp;face<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#end&nbsp;current_ent<br />&nbsp;</span><span class="syntaxdefault"></span>
                  (Still looking)
                  • thomthomT
                    I don't understand the rest of your code.
                    mini = 10000
                    What is this magic number?
                    current_norm_reverse.length = 1000
                    What is the purpose of this line?
                    • N
                      njeremy2
                      mini = 10000
                      me too, that code is from rectangleHoletool.rb from the link in my first post
                      • N
                        njeremy2
                        I made some test on that plugin.
                        If the entity is longer than ~25000 cm (more than 25400cm, I just test it), you can make any hole. If it's smaller than that value, it working
                        re-edit2 : I can make a hole in groups ! ๐Ÿ˜„ (many thanks thom !)
                        Now I still have the first problem...
                        • thomthomT
                          The logic for finding the opposite face is somewhat odd. The magic number is no good design and puts on an artificial limit.
                          I'm thinking that it'd be better to trace a ray to pick the opposite face. Shoot a ray from one of the vertices (or a calculated face centre) in the opposite direction of the face normal - see if it hit a face with a reversed normal. Then use that length to push-pull.
                          • thomthomT
                            Here is one alternative:
                            No working correctly!!
                            • thomthomT
                              Meh! Doesn't work for faces outside the current context... ๐Ÿ˜ž
                              • thomthomT
                                This one works. ๐Ÿ˜„
                                UPDATE: I'd forgotten to remove some old code. Please check the new version.
                                Removed some redundant code!
                                • thomthomT
                                  I saw a tiger lurking...
                                  http://images.bcdb.com/ad_im/wb/ltmm/putty_tat.jpg?u=
                                  ๐Ÿ˜ฒ
                                  • TIGT
                                    I made an inept and incorrect comment, which I then decided to erase ๐Ÿ˜ฎ
                                    You have fixed it now anyway...
                                    BUT where'd it go ๐Ÿ˜•
                                    Now it's back again... The art of illusion..........
                                    "Now you see it, now you don't."
                                    PS:
                                    The latest code method's model = face.model is now redundant, because you iterate through the face.parent.entities to find the matching 'back-face'...
                                    • thomthomT
                                      @tig said:
                                      PS:
                                      True that. (Won't bother to update for that one line though.)
                                      • N
                                        njeremy2
                                        ahahah
                                        AHAHAHAHAHA !!! Thank you thomthom !!
                                        It works great !!!
                                        Many many many .... (ctrl+C, ctrl+V) ... many thanks !! ๐Ÿ˜ ๐Ÿ‘
