    Paper sizes
    layout
    7 Posts 3 Posters 886 Views 3 Watching
    • M
      mwm5053
      In most of the info I read about LO I see there are presets for paper size (a drop down list) but I'm not seeing it on my system OSX using LO 3 and do all the templetes default to decimal until changed, maybe a good reason to save your own templete?
      2011 iMac
      SU 2015 Pro, 2017 Make
      V2 Twilight
      macOS Sierra 10.12.5
      • jeff hammondJ
        jeff hammond
        you pick your paper size when opening a new document..
        all the euro sizes (A3, A4, etc) will be in cm.. the others will be in inches
        also, if you'd rather not change the size via the dialog in your post, you can change your paper size according to your printer's capabilities using File -> Page Setup…
        dotdotdot
        • M
          mwm5053
          I got that part I was just wondering why the presets show up in some of the documentation I read
          2011 iMac
          V2 Twilight
          • jeff hammondJ
            jeff hammond
            that's a windows screenshot.
            mac presets are in file-> page setup...
            (ie- the same place/dialog as most Mac apps)
            dotdotdot
            • M
              mwm5053
              Oh thanks Jeff
              2011 iMac
              V2 Twilight
              • jeff hammondJ
                jeff hammond
                you can also change the units in the dialog you posted..
                click on units then switch to imperial.
                it should reflect in your paper sizes.
                dotdotdot
                • GaieusG
                  This screenshot is an A4 paper in millimetres for instance:
                  http://forums.sketchucation.com/download/file.php?id=88660
