    How can I shape a component to repeat along a curved track?
    3 Posts 3 Posters 404 Views 3 Watching
    • I
      imabzeous
      I have made this railway track and now i want this beautiful structure under it.. but the track is in curve so i don't know how to place it accurately.. can somebody help me and tell me how to do it? better if with images.. am attaching SU file..
      Track file
      • fuzzionF
        fuzzion
        Easiest 30 second way is TGI warp. But for some reason mines not working today 😑
        1 The slow way to is to create a plane. Use follow me along the bend of the curve
        2 Draw equally divided lines underneath for push and pull
        3 Draw the arcs of the bridge
        4 Push and pull arcs with + ctrl. Intersect selected model
        5 Remove intersected ( or use solid plugin)
        6 Push pull bottom parts to extend height
        rail_edit.skp
        "Only the dead have seen the end of war" - Plato
        • gillesG
          gilles
          You may try Shape bender:
          http://forums.sketchucation.com/viewtopic.php?t=18210
