    Layer Names to Array
    13 Posts 4 Posters 648 Views 4 Watching
    • K Offline
      ktkoh
      I used this line of code to make an array of layer names. However it makes an array of layers not layer names.
      layers = model.layers
      lname = layers.each {|e| e.name}
      It seems that I need to move the lname = inside the brackets but I had no sucess with what I tried. How should I make the array of names?
      Question 2: When I have the layer names how would I select a name that has only characters 0 thru 9 in lname(1,2)?
      Keith
        You are using each instead of map.
        Correct is:
        <span class="syntaxdefault"><br />layers&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">layers<br />lname&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">layers</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">map&nbsp;</span><span class="syntaxkeyword">{&nbsp;|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">name&nbsp;</span><span class="syntaxkeyword">}<br />&nbsp;</span><span class="syntaxdefault"></span>
          You refer to the ASCII character code?
          Or you want the first 9 characters in the string?
          (Beware that strings from SketchUp, such as layer names etc., is UTF-8 encoded - while Ruby 1.8 treats characters in a string as single bytes. Meaning if you extract the first 9 bytes of a string you might chop a UTF-8 character in half. Further reading: http://forums.sketchucation.com/viewtopic.php?f=180&t=20657 )
            It would be more logical to give your array a 'plural name' so it's more obviously a 'collection'
            lnames = model.layers.map{|e| e.name }
            Then
            lnames9 = lnames.map{|e| e.length <= 9 }
            B_U_T... as TT says - non-ASCII characters can give a false 'length' as they use 'two' bits...
            t="cat" cat t.length 3 t="cat½" cat½ t.length 5
            i.e. NOT 4 ... the '½' appears as one character but it takes two bits...
              This snippet finds all layers with less than 9 unicode characters:
              <span class="syntaxdefault"><br />lnames </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">layers</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">map </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">layer</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> layer</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">name </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">lnames9 </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> lnames</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">select </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">layername</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> layername</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">unpack</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'U*'</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">length </span><span class="syntaxkeyword"><=</span><span class="syntaxdefault"> 9 </span><span class="syntaxkeyword">}<br />&nbsp;</span><span class="syntaxdefault"></span>
              Or, if you want to collect the Layer objects directly:
              <span class="syntaxdefault"><br />lnames9&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">layers</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">select&nbsp;</span><span class="syntaxkeyword">{&nbsp;|</span><span class="syntaxdefault">layer</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">layer</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">name</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">unpack</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'U*'</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">length&nbsp;</span><span class="syntaxkeyword"><=&nbsp;</span><span class="syntaxdefault">9&nbsp;</span><span class="syntaxkeyword">}<br />&nbsp;</span><span class="syntaxdefault"></span>
              • Dan RathbunD Offline
                Dan Rathbun
                No guys he wants names that have numerical characters in the 2nd and 3rd positions.
                ... only characters 0 thru 9 in lname( 1,2)?
                A regular expression is easiest:
                num_layers = model.layers.find_all { |layer| layer.name =~ /\A\D\d\d/ }
                num_layer_names = num_layers.map { |layer| layer.name }
                The pattern escape sequences mean:
                \A the begin of the string
                \D a char that is NOT a digit
                \d a char that IS a digit
                .. and we don't care about the rest of the name.
                If we get a match, the integer char position of the match (and will be 0 because we used \A,) is returned by the =~ method, otherwise for no match it returns nil (which evals to false so is not included in the output array from find_all.)
                The find_all method comes from the Enumerable mixin module, which is mixed into the Sketchup::Layers class, viz:
                Sketchup::Layers.ancestors %(#008000)[>> [Sketchup::Layers, Enumerable, Sketchup::Entity, Object, Kernel]]
                I'm not here much anymore.
                • K Offline
                  ktkoh
                  Thanks for your help. Dan was correct the pattern I am looking for starts A00- thru A99- and his code worked very well.
                  Keith
                    Dan Rathbun
                    For more on Regular Expressions, see the old "Pick-Axe" book:
                    Programming Ruby: The Ruby Language (Regular Expressions)
                      Is regex unicode aware by default in Ruby 1.8, or do you have to enable a flag? There is still the risk of getting part of a multi-bye character if it isn't.
                        Dan Rathbun
                        OK.. IF the first character is unicode and multi-byte, he could use a OR thus (and I add into the pattern the dash he has after the two digits):
                          layer.name =~ /\A\D\d\d-/ ||
                          # 1st char multibyte unicode
                          # m opt allows . bytes to be any char
                          layer.name =~ /\A..\d\d-/m
                        • K Offline
                          ktkoh
                          I thought you might find this interesting:
                          Last night I copied and pasted Dan's code into the web console and the code worked as expected. I added the dash at the end and also added a line to sort the file names still working. Wife says baseball is starting so I save the snippet and go in to watch the Reds. Now this morning I reload the saved file and nothing works. So I repeat the process from last evening and after pasting Dan's code in it again works. I have experimented today and found in the web console I cannot save and reload the code and get it to work. Any Thoughts on this??
                          Keith
                            There are different verions of the webconsole out there - which one do you use?
                            • K Offline
                              ktkoh
                              I use webconsole.rb Copyright (C) 2006 Jim Foltz
                              and have not looked for updates.
                              Keith
