    Edit raw vertex data
    4 Posts 3 Posters 416 Views 3 Watching
      rossthompson
      Hi guys,
      I have worked with a couple of other CAD programs that provide you with a window for editing raw vertex data. See attached image. I was wandering if something similar would be possible in SketchUp?
      I appreciate this doesn't actually add any functionality, but it is a very direct way of moving points to absolute positions.
      I hope this makes sense.
      Ross
        You're asking as a user? Not a developer?
        In Vertex Tools v1.1 (not released yet) I added absolute and relative VCB positioning for the Move tool - like the native Move tool has.
        A window like the one you display there would be possible - but not for version 1.1. But if you could describe a case usage example for it I might look into it for version 1.2.
          rossthompson
          Hi Thom Thom,
          Thanks for the response. I dabble in writing my own scripts, but I wouldn't know where to start on this one! So I guess I'm asking as more of a user.
          I came across a situation this morning where I was working with some imported geometry from another company. There was a long row of pillars all with slightly different Z-coordinates, I wanted to normalise them to a certain position in Z. Hopefully the attached image illustrates this.
          I know this could easily be done with the move tool or the push/pull tool, but I reckon using a vertex table would have to be quickest/most direct. It could also have applications for checking geometry i.e. when you can't create a face because the bounding edges are not co-planar.
          Ross
            Find my DropVertices tool
