    Problem adding instance of child component
    7 Posts 4 Posters 361 Views 4 Watching
    • K Offline
      ktkoh
      My script is intended to add a instance of a child component outside of the parent component. The script starts as a context selection when a child component is selected. The user needs to open the parent for editing to select the component.
      UI.add_context_menu_handler do |popup|
            sel = Sketchup.active_model.selection
            unless sel.empty?
              if sel.single_object?
                obj = sel[0]
                if obj.is_a?(Sketchup;;ComponentInstance) &&
                obj.parent.is_a?(Sketchup;;ComponentDefinition)
                  popup.add_item(NC2SCENE) {
                    nested_component_command(obj)
                end # component test
              end # single_object?
            end # unless empty?
          end # add_context_menu_handler
      and I have not found a method to close the parent component and then when I add an instance of the child it is added inside the parent which is not what I need. The instance needs to be added to the model outside of the parent component.
      Keith
        Assuming 'obj' is an instance... using
        obj.parent
        will return the actual 'container' of 'obj' - which might be the model or a group/component-definition].
        Use
        definition=obj.definition model.entities.add_instance(definition, transformation)
        to add an instance into the model itself using a 'transformation' - which you might get from the 'obj' and its 'container' instance...
        • Dan RathbunD Offline
          Dan Rathbun
          @ktkoh said:
          ... and I have not found a method to close the parent component ...
          use: Model # close_active()
          as in:
          Sketchup.active_model.close_active()
          I'm not here much anymore.
          • K Offline
            ktkoh
            I used the Sketchup.active_model.close_active() and it worked as advertised.
            Thanks (I wish sometimes I could find these on my own)
            Keith
              Dan Rathbun
              The API Method Index really helps find things.
                Note that the method is bugged and doesn't add the operation to the undo-stack - so if the user undo operations you might see some unexpected results. No workarounds atm.
                • K Offline
                  ktkoh
                  Ok I tried the other method
                  c2=@model.entities.add_instance(ent_def,insert_tran)
                  when I first looked at the suggestion I thought that was how I added the instance in my origional code but closer inspection I noted that I was using
                  c2=@model.active_entities.add_instance(ent_def,insert_tran)
                  Once I replaced active_entities with just entities the code worked also.
                  Keith
