    Sandbox and Views
    24 Posts 6 Posters 1.5k Views 6 Watching
    • brookefoxB Offline
      brookefox
      To me it matters; I don't mind learning something new. He said plan view and I would not have imagined that a 'select all' and a crossing window across the extents screen would not, in fact, select all. Must check that. Perhaps you knew. I don't know.
      Thanks for the image and explication.
      ~ Brooke
      • W Offline
        wyatt
        You are correct, and I am sorry for making light of your question. I actually cannot explain why 'select all' or a crossing selection in plan does not select the guide. Everything looked normal for me in plan view, and I only discovered the clipping and the visible guide when I orbited.
          brookefox
          ~ no bump ~
          Thanks.
          πŸ‘
          ~ Brooke
            It's as I said earlier, any object within a model or a component/group that is 'miles' from the origin [even when it's unseen] will affect the model's extents and exacerbate the 'clipping-plane' problem.
            That particular guide-line is ~60 kilometers [~40 miles] away from the origin πŸ˜’
            • 2 / 2
