    DMC Sampler Question
    renderpluginsextensions
    1 Posts 1 Posters 259 Views 1 Watching
    • V
      valerostudio
      I was under the impression that if you increase the Subdivs Mult in the DMC Sampler then it will increase all Subdiv properties globally.
      Now I made a test file and rendered with the Mult at 1.0 and then at 5.0 - there is an improvement in the quality of a glossy material I am testing but if I reset back to 1.0 and go into the material and change the Subdiv from 8 to 40 (5x) then the quality is much higher. Shouldn't this just be a numbers game and get the same result?
