    Single Room-WIP
    13 Posts 4 Posters 2.4k Views 4 Watching
    • stefanqS
      stefanq
      Hi all, some recent work in a difficult space. I think I managed to fit all the things client need.
      Some c&c would be awesome. Sofa, chairs and tables are components from the warehouse.
      Regards,
      Stefan
      • brookefoxB
        brookefox
        Its tight and so for me the somewhat jumbled, informal look of the media/shelving wall does not work as well as the others. I think if you brought some order and elegance to that wall things would be more relaxed and successful, but that is certainly a view fraught with personal preference...
        Is the pendant light fixture (honey server) your own design?
        ~ Brooke
        • stefanqS
          stefanq
          No, I forgot about that, sorry, must be a 3ds model saved in my personal library, but I can share it if you need it tomorrow,when I go to work.
          I really appreciate your comments, thank you, I'll try something else to that wall, something easy to the eyes, but it's tricky, since that is a gypsum wallboard type of wall.
          Regards,
          Stefan
          • stefanqS
            stefanq
            This is a render I did in early stages just to test materials. I'll cook some more, after I meet with the client.
            I have some issues with the noise in reflections, due the fact that I have the sun going through the glass. I have to tweak the settings more. This is a V-ray render, by the way.
            • brookefoxB
              brookefox
              Certainly only if it is convenient and can be imported natively. Thanks for the offer.
              ~ Brooke
              • stefanqS
                stefanq
                Here is the pendant lamp model
                skpB8.rar
                • stefanqS
                  stefanq
                  People and color choices.... πŸ˜’
                  • StinkieS
                    Stinkie
                    Nice render.
                    • stefanqS
                      stefanq
                      Thanks Tom. Previous, I had to do some "gymnastics" in the V-ray frame buffer(adjustments) in order to make the image brighter, but I remembered Fernando's technique who basically used nothing in the GI slot, but a blue color with a big multiplier (40 or so), and enabled the sun in global switches (Default Lights). In this way, you don't need to put rectangular lights in the windows. I used HSV Exponential as color mapping, because I wanted to keep my colors saturated. I like the quality of the render, but I think this approach of lighting the scene was responsible for the pleasing result.
                      In the end, all that matters is to find what works best. I bet if I had to render a different scene with the same approach, it will turn worse, or.... better.
                      Cheers!
                      • brookefoxB
                        brookefox
                        Stefan, thanks for posting the light fixture.
                        ~ Brooke
                        • stefanqS
                          stefanq
                          You're welcome! OK, some more images with minor modifications, these should be the last ones, as I got bored of the project. It's coming along quite slow. Still, it was fun, I was missing rendering so much.
                          Regards,
                          Stefan
                          • N
                            ninopiamonte
                            Maybe you should try black, white, beige, dark brown colors?! Awe!
                            • stefanqS
                              stefanq
                              Ciao Nino, I've used different color combinations, but now it's out of my hands. Like I said in a previous post: "people and color choices" .
                              Thanks for your comment!
