    Single Room-WIP
    13 Posts 4 Posters 2.3k Views 4 Watching
    • brookefoxB Offline
      brookefox
      Its tight and so for me the somewhat jumbled, informal look of the media/shelving wall does not work as well as the others. I think if you brought some order and elegance to that wall things would be more relaxed and successful, but that is certainly a view fraught with personal preference...
      Is the pendant light fixture (honey server) your own design?
      ~ Brooke
      • stefanqS Offline
        stefanq
        No, I forgot about that, sorry, must be a 3ds model saved in my personal library, but I can share it if you need it tomorrow,when I go to work.
        I really appreciate your comments, thank you, I'll try something else to that wall, something easy to the eyes, but it's tricky, since that is a gypsum wallboard type of wall.
        Regards,
        Stefan
        • stefanqS Offline
          stefanq
          This is a render I did in early stages just to test materials. I'll cook some more, after I meet with the client.
          I have some issues with the noise in reflections, due the fact that I have the sun going through the glass. I have to tweak the settings more. This is a V-ray render, by the way.
            brookefox
            Certainly only if it is convenient and can be imported natively. Thanks for the offer.
            ~ Brooke
            • stefanqS Offline
              stefanq
              Here is the pendant lamp model
              skpB8.rar
              • stefanqS Offline
                stefanq
                People and color choices.... πŸ˜’
                • StinkieS Offline
                  Stinkie
                  Nice render.
                  • stefanqS Offline
                    stefanq
                    Thanks Tom. Previous, I had to do some "gymnastics" in the V-ray frame buffer(adjustments) in order to make the image brighter, but I remembered Fernando's technique who basically used nothing in the GI slot, but a blue color with a big multiplier (40 or so), and enabled the sun in global switches (Default Lights). In this way, you don't need to put rectangular lights in the windows. I used HSV Exponential as color mapping, because I wanted to keep my colors saturated. I like the quality of the render, but I think this approach of lighting the scene was responsible for the pleasing result.
                    In the end, all that matters is to find what works best. I bet if I had to render a different scene with the same approach, it will turn worse, or.... better.
                    Cheers!
                      brookefox
                      Stefan, thanks for posting the light fixture.
                      ~ Brooke
                      • stefanqS Offline
                        stefanq
                        You're welcome! OK, some more images with minor modifications, these should be the last ones, as I got bored of the project. It's coming along quite slow. Still, it was fun, I was missing rendering so much.
                        Regards,
                        Stefan
                        • N Offline
                          ninopiamonte
                          Maybe you should try black, white, beige, dark brown colors?! Awe!
                          • stefanqS Offline
                            stefanq
                            Ciao Nino, I've used different color combinations, but now it's out of my hands. Like I said in a previous post: "people and color choices" .
                            Thanks for your comment!
