    Plug in for convex surface
    6 Posts 3 Posters 1.0k Views 3 Watching
      marcuus
      Hi, I would like to know if it exists, and where I can plug in a free download for the free version of sketch up 8 that allows you to instantly create concave or convex surfaces not geometric ,(not too much complicated)like surfacegen ,such as those seen in my models in 3d warehouse sketch up by marcuus99, previously selecting the baselines of the face that you want to process, thanks in advance πŸŽ‰
      marcuus99
        Seems Curvy Loft By Fredo 6, some Extrude tool by Tig, Soap Skin Bubble , Ferrari... can make forms like that πŸ˜‰
        And you make some thickness with Joint PushPull by Fredo6 πŸ˜„
        Here Ferrari
        http://forums.sketchucation.com/download/file.php?id=58198
        http://forums.sketchucation.com/download/file.php?id=58250
          marcuus
          thank you pilou, i download both of them, but they doesnt work,
          may be miss some application called fredo 6 in plug in folders?
          where i do download this? ❓ πŸ˜„
          ok , i try again, thank you
            The CurviLoft download page says you also require 'LibFredo' - it has a link to get that too.
            Ensure you extract and install the files and subfolders of files exactly as directed...
              marcuus
              in the case of the description of the tutorial in the boat plug in soap skin can be seen that the last 5 or more vertical lines on the side of the tip are all straight lines, instead of maintaining and transporting all the way around the boat's roundness arc stern, mathematically calculating the chord of the semicircle to be reduced to the tip of the boat. πŸ˜•
              Then I successfully installed the plug in of soap skin ,there are the tool icons and it works, but i can not enter the values of pressure, only the ratio values, πŸ˜• I should try to uninstall and reinstall all again, now I try with the plug in the extrude tool if it goes better
              then first one
              Therefore, in my opinion the same result is obtained with the old sandbox,
              although it is always questionable opinion, what do you think?
              (I apologize for the English, if not well described is the fault of google translate) πŸ˜„
                marcuus
                %(#0080FF)[Thanks Tig, I have now downloaded and tried the 'extrude tool, beautiful, simple and effective, including the toolbars I found the tutorial here that I read quietly after translating them, and learned well, thank you
                many. β˜€ πŸŽ‰]
