Vray Load Error
I have been successfully using vray for a few renders through this week. However, I opened the same skp file I've been using for these renders where the message now appears:
Error Loading File C:\ProgramData/ASGVIS/VfS/Ruby/R2P.rb
#<REXML::ParseException: malformed XML: missing tag start Line:
Position:
Last 80 unconsumed characters:
<parameter list T Error Loading File vfs.rb
Position:
<parameter list TThe file opens fine once I click ok but obviously vray won't render.
Here is the R2P.rb file if anyone has any suggestions?
Sketchup version - 8.0.3117
Vray version - 1.48.96
I would say something happened to your Vray ruby file. Perhaps re-installation is in order, and there is also a newer version out which might help out on some other issues you might or might not have had.
Rob
Register LoginAdvertisement
