    Req, help with this Wind Turbine.
    8 Posts 5 Posters 1.3k Views 5 Watching
    • kaluK Offline
      kalu
      Hi Guys:
      I have to create a design park for kids for my comunity and I need help. I hope someone can help me to design this wind turbine, since they want some art include I think this would be great for the park. I try to build the turbine without any good result. If soneone can help to build I really appreciate.
      Kalu πŸ˜„
      πŸ˜’
      THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
        Starling75
        Look closely at the shape of blade profilation of the VAWT on picture and compare it with your design ...
        Flat side of the wing shaped blade is exposed to wind and it is also slightly twisted..
        http://inhabitat.com/wp-content/blogs.dir/1/files/2010/09/wind-turbine-eddy-t.jpg
        http://www.starlingarch.cz
        • kaluK Offline
          kalu
          Thank you for your comments. I try buut I can't make the same effect , does anybody have this model or can help to at least build one of the Blades?
          I really appreciate. β˜€
          • brookefoxB Offline
            brookefox
            So this is to be 'art,' not an electricity producing thing; it is not just a rendering but will be built. I would suggest posting your work so far, at least pics of it as well as specific questions about your problems.
            Did you search for product info?
            ~ Brooke
            • fuzzionF Offline
              fuzzion
              Use Tgi 3d creat mesh for the blades
              "Only the dead have seen the end of war" - Plato
              • oganocaliO Offline
                oganocali
                Here is a quick attempt at the blades. I suggest you learn to draw this with the help of a few plug-ins.
                i: draw the profile of the blade using some sort of Bezier curve plug-in (there are many alternatives).
                ii: draw a helix (using follow me helix plugin (just do a search on that name))
                iii: perform extrusion using the regular follow-me tool.
                rest is copy rote the blades.
                turbine.skp
                • fuzzionF Offline
                  fuzzion
                  Not sure if this is similar to what you wanted. Had some free time from work πŸŽ‰
                  • kaluK Offline
                    kalu
                    Thank you to all for the amazing help. I was visiting my mom sick. I am back and thank you again for an amazing help guys.
                    kalu. 😎
