    Automaticly generated "hidden lines." Why?
    3 Posts 3 Posters 302 Views 3 Watching
    • S
      Sorceress21
      I often find myself dealing with SU automatically generating "hidden lines" on properly squared faces after I do an intersect. Does anyone know why this happens? Is it a bug or is this supposed to occur? It drives me crazy as it causes "unsoftened" areas to appear especially on curved faces. For those that don't know a "hidden line" is different than a "softened" line. A softened line is a longer dash pattern then hidden lines.
      • jeff hammondJ
        jeff hammond
        it's because your faces aren't actually co-planar as you think they are.. if you upload a model showing this behavior (or portion of said model), i or someone else can point out the cause..
        dotdotdot
        • thomthomT
          I see that from time to time when I'm working on imported geometry - it appear to be some small inaccuracy issue which compound eventually to problematic inaccuracy.
