    Can't find rendered EXR/VRIMAGE file...
    renderpluginsextensions
    5 Posts 2 Posters 1.9k Views 2 Watching
      tomvokurka
      Hi there.
      I'm new here, so I apollogize for anything I don't know yet πŸ˜„
      But I have a litlle tricky problem with my render. I'm trying to render a model in resolution of 5000x3500 pixels.
      I knew that Vray has setting to save RAM, so I tried to render to Vray Raw image, both EXR and VRIMAG formats.
      It seemed cool, rendering for almost an hour. But unfortunately, Sketchup told me, that rendering is complete, but I couldn't find any EXR or VRIMAG file. I have typed path to a save-file in a row in a "Save to VRI" setting before rendering. So everything seems okay, except of that issue, when I can't find the rendered result.
      Did anyone heard of that sort of problem? It's a litlle bit exhausting, render for hours and than realize, there's nothing to work with.
      Thanks so much for advices!
      Tom
      • andybotA Offline
        andybot
        Hi Tom, did you type in (or browse to) a filename and a directory path next to the autosave option? Look in the output tab and make sure there's a filename selected. I would do a quick test with a low resolution render first. If you had a filename but no path, it may have gone into some default directory like TEMP or your vray program folder... Hope that helps,
        Andy
          tomvokurka
          Hi Andy. Thanks for your concern.
          Well, I tried to render smaller image and it almost worked.
          Problem came when I tried to render the same picture into another file with another name.
          Then I coudln't find it as I have mentioned in the first post.
          Now I'm trying to render my 5000 pixel image to my desktop - I chose that destination in browser that appeared after clicking on that link on the right side of the checking-box of "Render to VRImage".
          It seemed fine, but now the Frame Buffer appears to crash (those small rendering-rectangles are not moving) and even my pc seems to be calmer than in a regular render process. I've checked how much RAM uses SU. That surprised me a litlle bit, it shows me, that almost 1,5 GB of RAM is in use of SU right now. Does that mean, it's still rendering? I suppose so, even when my frame buffer has frozen. Any advices to deal with that?
          Yeah and I found that in Output slot, under VRI setting is option: VFB mode. What should be in there, and what is it for?
          Thank you πŸ˜„
          Tom
            tomvokurka
            So I've tried to render smaller images, and after a long time, I found out the destination of TEMP-saving files. That problem is maybe solved.
            Now I have another issue. When I've rendered to EXR file, it looked fine, but no HDRi background have been rendered. Is there anny setting of rendering or not-rendering HDRis? Or it is a problem of EXR format?
            And the last question is: where can I find some VRIMAG to EXR converter? I thought about possibility, that vrimag could save those HDRis.
            Thank you!
            Tom
            • andybotA Offline
              andybot
              try un-selecting the alpha channel in the vfb options. That should give you an exr without transparency.
