    Explode group, retrive all entities and recreate group
    14 Posts 4 Posters 1.7k Views 4 Watching
    • N Offline
      njeremy2
      Hello everyone, I need you πŸ˜„
      I have this code :
      def DefToName
      @tab = []
      @tabgroup = []
      #retrive all entities
      Sketchup.active_model.entities.each do |entities|
      # put all entities into TAB called @tab
      @tab << entities
      	@tab.each do |element|
      	%(#00FF00)[# If the entity is a group, explode the group]
      		if element.is_a?(Sketchup::Group)
      		element.explode
      %(#FF0000)[# I need to retrives all entities from this group HERE,
      # If I put this code : "Sketchup.active_model.entities.each do |entities|" it takes all entities, and I just need only entities from the group
      # after explosion, I'll do actions on this entities (ComponentInstance or Group)
      # After actions, I need to recreate the group with all the entities from this group.
      # For recreate the group, I have to pick the name of group before explosion into @name for example,
      # Then, when I need to recreate the group, I put that name into the new name of group
      		end %(#00FF00)[#is_a?]
      	end %(#00FF00)[#tab.each]
      end #|entities|
      end # end DefToName
      Thank you πŸ˜„
        Use a lowercase letter for the start of a def method.
        You method will not be robust.
        If you get a list of the group's entities when you explode it, they might not all exist when you want to come to recreate it - coincident edges/faces can merge.
        Why do you need to explode and remake each group in the model ?
        Why not simply iterate the model.entities and for each group found you then do something to the group.entities, iterating that for other groups or whatever... no explode no remake needed πŸ˜•
        Sketchup.active_model.entities.each{|g|
          next unless g.is_a?(Sketchup;;Group)
          g.entities.each{|e|
            next unless e.is_a?(Sketchup;;Group)
            puts e
            # or whatever you want to do with 'e'
        • N Offline
          njeremy2
          Hmmm,
          It seems to be good, I will try to execute it
          I have a group which contains components. And with this component, I need to copy definition name into name (the copy works thanks to you. Thank to you TIG!!).
          So, to access to this component for doing modification, I tought I need to explode it.
          You just tell me it's possible to make modification without exploding groups.
          I will try this and I tell you if it's work or not. πŸ˜‰
          • N Offline
            njeremy2
            How do you use "next unless" ?
            I search it into "Automatic_SketchUp.pdf", I found nothing
            • K Offline
              kwalkerman
              "next unless" is ruby code - no Sketchup needed. TIG's code basically says "unless g is a Sketchup::Group, move on to the next item in each. It is functionally the same as the following, but reads a little cleaner:
                if g.is_a? Sketchup;;Group
                  g.entities.each{|e|
                      puts e
                When you do a 'test' you can do it like this
                ` if e.is_a?(Sketchup::Group)
                do stuff
                end#ifif you want to negate the match use if not e.is_a?(Sketchup::Group)
                do stuff
                end#ifor if ! e.is_a?(Sketchup::Group)
                do stuff
                end#ifthere is the opposite of 'if' which is 'unless', so unless e.is_a?(Sketchup::Group)
                do stuff
                end#unless`
                where 'unless...' is the same as 'if not...'
                Now when you make a if...end or unless...end block and you nest other blocks of code within those it's easy to loose track of which 'end' ends what!
                I prefer to use a one line test to skip or jump out of a block.
                ` es.each{|e|
                next unless e.is_a?(Sketchup::Group)
                not a group so skip to the next item
                OR we do stuff to e because it IS a group!
                }the next unless e.is_a?(Sketchup::Group)is the same as next if not e.is_a?(Sketchup::Group)You don't need an 'end' to a single line test where it follows the action. The 'next' simply skips to the next item in the array/list. Using 'break' stops the iteration - useful if you are testing for ONE thing and you have found it... like g=nil
                es.each{|e|
                if e.is_a?(Sketchup::Group) and e.name=="FOO"
                g=e
                break
                end#if
                puts g if g`
                which sets 'g' to nil, but then makes it a reference to ONE group named 'FOO' if it's found in the tested list, if found it breaks out of the {} and 'puts' it... Note how the 'g' is defined outside of the block {} so you can use it later, references initiated inside a {} are not visible to later processes.
                One tip more... you can iterate an 'entities' collection just as it it were an array, BUT if you intend to do anything to the items in the collection, like erase some, then you must convert it into a snapshot array as you start because otherwise your changes will change the entities collection as you iterate through it and give unexpected results...
                So use
                group.entities.to_a.each{|e| e.erase! unless e.is_a?(Sketchup::Edge) }
                to erase everything in a group that is not an Edge - i.e. all faces and groups etc.
                group.entities.each{|e| e.erase! unless e.is_a?(Sketchup::Edge) }
                will fail to erase everything as the list will change dynamically as you change it, and so some might get missed.
                • N Offline
                  njeremy2
                  Hmmm, I will meditate on this.
                  It's a new notion for me, let me a little time to understand it
                  now, I try the code
                  [edit]
                  WOOOOOW TIG !
                  I don't have time enough to read all answer and you wrote that !! 😲
                  • N Offline
                    njeremy2
                    lol !
                    wowowowo!
                    I have 2 bigs difficulties :
                    The first one is to understand correctly the English πŸ˜„ (I can manage that)
                    The second one is to understand Ruby and SketchUp language subtleties ---> AAAHHHH 🀒
                    • N Offline
                      njeremy2
                      I try this code
                      Maybe I don't know how to use that...
                      What I need to do is to retrive all entities, then I select what I need to do if it's a group or if it's a component.
                      If it's a component, I copy the DefinitionName into Name.
                      If it's a group, I need to copy DefinitionName into Name for all components into the group
                      The problem : I don't know how get into the group then copy the definition without exploding this
                      code for copying definition into name
                      if	element.definition.name[0] != 0 && element.name == ""
                      element.name = "#{element.definition.name}"
                      end # end if
                        You seem to be making this too complex...
                        Your last piece of code seems to make no sense πŸ˜•
                        Every definition has a unique name that is a 'string'.
                        Please try and explain [simply] what you want to do - in words, not code...
                        It IS straightforward to find definition/instance names, BUT what do you want and what will you ultimately do with them ???
                        • N Offline
                          njeremy2
                          I'm a student in computer science into a small business. My boss use Sketchup Pro and he asks me do make a plugin which count all entities in a design.
                          It tells you how many components and groups are they in the design.
                          We have already use that plugin but there are some bugs.
                          If we don't put a name into the component, the plugin display nothing (that's why I ask you how to copy definition name into name).
                          The other problem is : when you have a group, into that group you can have some components and the plugin didn't count these components, that's why I ask how to get into a group without exploding this.
                          Voila πŸ˜„
                            OK !
                            Let's start at the other end... πŸ˜’
                            Rather than try and mine into the model, shortcut it by examining definitions...
                            A model has definitions.
                            These refer to components, groups and images.
                            Definitions have instances methods, so you can count how many there are etc.
                            This example code iterates through all of the model's definitions, list their type, name, instances [with name and parent] etc...
                            model=Sketchup.active_model
                            collection=[]
                            model.definitions.each{|defn|
                              details=[]
                              if defn.image?
                                details << "IMAGE"
                              elsif defn.group?
                                details << "GROUP"
                              else #component
                                details << "COMPO"
                              if defn.image?
                                details << defn.path #images have no name
                              else
                                details << defn.name
                              insts=[]
                              defn.instances.each{|ins|
                                inst=[]
                                if defn.image?
                                  inst << '' #image instances have no name
                                else
                                  inst << ins.name
                                par=ins.parent
                                if par==model
                                  inst << "MODEL"
                                else
                                  inst << par.name
                                insts << inst
                              details << insts
                              collection << details
                            collection.sort!
                            puts collection
                            OR write [puts] 'collection' into a file etc...
                            The format is
                            COMPO, Compo#1, , Group#1 COMPO, Compo#1, Cxxxxxx, MODEL GROUP, Group#1, MyGroup, MODEL GROUP, Group#2, , Compo#1 IMAGE, C:/Temp/My.png, , MODEL
                            etc
                            the empty fields ', ,' is where an instance or group has no name assigned.
                            • Dan RathbunD Offline
                              Dan Rathbun
                              Does your boss ever use the
                              Model Info > Statistics panel ??
                              I'm not here much anymore.
                              1 Reply Last reply 😊 Reply Quote 0
                              • N Offline
                                njeremy2
                                http://forums.sketchucation.com/download/file.php?id=87554
                                [attachment=1:1ebrpxvl]<!-- ia1 -->ModelInfo_Statistics.png<!-- ia1 -->[/attachment:1ebrpxvl]
                                Yes he knows this tool, but it don't give you the texture (in m²) and of the components neither groups 😞
                                thanks to all everybody !!! I think I found the solution. πŸ‘
                                When I need to found each entities in a group I use that :
                                if g.is_a?(Sketchup;;Group)
                                	g.entities.each do |element|
                                		end # end if
                                	end #|element|
                                With that, I can change the name of component inside a group
                                The first code of TIG gave me an idea, I combine my code with a piece of code from him and it worked ! (it was only a sample of code used to test for me)
                                Now I have to copy that piece of code in the big one ! πŸ˜„
                                Before :
                                http://img205.imageshack.us/img205/1108/33890297.png
                                After launching the plugin :
                                http://img585.imageshack.us/img585/7154/18942418.png
