    No Hidden geometry
    7 Posts 2 Posters 777 Views 2 Watching
    • A
      Anthony R
      I've got a problem with Su8 It seems that hidden geometry works fine when I first download it but when I open it up for a second time hidden geometry no longer works. Which is to say it won't show hidden geometry
      I still have SU7 installed and it workes fine
      any surgestions would be greatly appreciated
        Can you give us some details of your system's GPU?
        Is it that when you toggle hidden geometry on/off you are not seeing any hidden geometry?
        • A
          Anthony R
          I'm running XP Pro. gigabite sis661fx onboard graphics card. Yes its when I toggle hidden geometry I don't see the hidden geometry. All works fine untill I open it the next day and after I've Set it up. I'm wondering if it could have somthing to do with plugins I copied across from Su7 folder but they all seemed to work well untill the next day. Thanks for the reply
            Can you try turning Hardware Acceleration off under Preferences?
            • A
              Anthony R
              "Bingo" that did it, Thanks Rich you were the right person in the right place at the right time.
                Can you update your drivers and enable it again?
                If it doesn't fix it then your GPU is a bit low end to run Sketchup.
                Disabling Hardware Acceleration isn't fixing it. It's identifying that it can't run SketchUp.
                Its an integrated card rather than a dedicated one.
                • A
                  Anthony R
                  Your absolutely right Rich I've always been aware that my card is not up to par but it's the hole unit that needs upgrading I'm just not sure which way to go.I can make complicated models but I have to keep away from using textures. Thanks again for your help
