    Mini-challenge
    328 Posts 26 Posters 74.1k Views 26 Watching
      Thomas, see Pilou's last post in this thread.
        Wasn't that related to Gaieus' guideline experiment?
          The thing absolutly crazzy is that the Rotation tool
          seems accept just the base alignement as only good alignement! ๐Ÿ˜ฒ ๐Ÿ˜ฒ ๐Ÿ˜ฒ
          I am totally depited! ๐Ÿ˜ฎ
            I get the result he shows in his close up when I try to use his method.
              I see the issue now. doh!
              ๐Ÿ˜•
              ...and I thought I had gotten peace at mind... ๐Ÿ˜ž
                So how do you calculate it?
                  arg... I keep wanting to make quide circles... I see how difficult this is with native SketchUp now...
                    I'm not sure how you'd calculate it. I think the only dimension you know is the width of the board. the length of the miter and the length between ends will change as the angle changes due to changes in the spacing between posts and the height of the posts. And you don't know any of the angles either.
                      • Width of the board
                      • Diagonal of the board
                      Surely this should be something to work on?
                        But you don't really know the length of the diagonal of the board when the miters have been cut. And the overall length of the board is immaterial.
                        If you working in real wood, you would get an estimated length so you know the piece of wood you offer up is plenty long. You'd nail it in place and cut the ends off flush with the posts.
                          @jason_maranto said:
                          This is really easy with the native tools -- here's a short tut file: [attachment=0:3gkxsinp]<!-- ia0 -->challenge.skp<!-- ia0 -->[/attachment:3gkxsinp]
                          Best,
                          Jason.
                          How do you place the horizontal guides such that you get the fixed width of the diagonal board?
                            Looking at it, it's just as if you skewed a 0,50m board - which is not correct.
                            • jason_marantoJ Offline
                              jason_maranto
                              This is really easy with the native tools -- here's a short tut file: challenge.skp
                              Oh, I see why this might be a challenge -- you want a specific width to the crossboard... give me a sec.
                              Best,
                              Jason.
                              • andybotA Offline
                                andybot
                                Too funny Jeff. I do this all the time in AutoCAD with a circle guide, but stupid sketchup segmented circles, I really don't see any way. Thanks for the brain melt... ๐Ÿ˜†
                                  Until today I have never been too bothered about SketchUp's segmented arcs and circles - I've always found a way around it. But this... arrrrhh!!!
                                  And - I noticed if you have a circle, make a pie segment where one line snaps from centre til vertex and the other from centre to mid-segment - SketchUp will claim the segment is an Arc. But it's not! ๐Ÿ˜ฒ I was thinking that if I adjusted the segments with the Entity Info the arc would readjust the two ends to be true to it's original circle - but instead it result in two different length radius.
                                  • andybotA Offline
                                    andybot
                                    ... thus - for best accuracy, draw it in ACAD and import into sketchup ๐Ÿ˜’
                                      Have you the files in V6 ? ๐Ÿ˜‰ (save as V6)
                                      • E Offline
                                        Ecuadorian
                                        Amen. Trimble, if you're reading this, we need actual arcs and curves in SketchUp.
                                        -Miguel Lescano
                                          Jason, that not quite the same as the original challenge, though. Make it so the diagonal board's ends are mitered with vertical cuts, not horizontal ones.
                                            jason_maranto
                                            I cleaned it up, streamlined the process a bit (removed a few unnecessary steps) and saved for version 6: challenge_final.skp
                                            I was looking at the very first image in the thread, is that not what we are shooting for here?
                                            Best,
                                            Jason.
                                            • 16
                                            • 17
                                            • 3 / 17
