    Mini-challenge
    328 Posts 26 Posters 99.4k Views 26 Watching
      @thomthom said:
      @dave r said:
      Jeff, I've had to draw diagonals like this a number of times and not found an elegant solution. It's always been via brute force. I forgot about TIG's True Tangents.
      Pilou's method was quite easy and simple. And also accurate!
      Yes, his way works, sort of. The second rotation is not perfectly accurate, though. I meant to simply draw it in place.
        Seemed to snap perfectly in my test... what am I missing?
        Ah - no post-cropping?
        • oganocaliO
          oganocali
          Nice challenge by the way, at first I thought this should be easy but then...
          You can also perform the rotation as a tangent to the drawn arc, (referencing the vertices on the arc). Of course it is not exact but the angular error is vanishingly small (approximately a^2*t/l ; t,l thickness and length of the rail, a is angular resolution on the arc (total angle/number of segments) in radians)). The final rotation accuracy increases with the square of the number of segments on the arc. After a few hundred segments SU makes the structure ideal at explode.
          Ogan
            Thomas, see Pilou's last post in this thread.
              Wasn't that related to Gaieus' guideline experiment?
                The thing absolutly crazzy is that the Rotation tool
                seems accept just the base alignement as only good alignement! ๐Ÿ˜ฒ ๐Ÿ˜ฒ ๐Ÿ˜ฒ
                I am totally depited! ๐Ÿ˜ฎ
                  I get the result he shows in his close up when I try to use his method.
                    I see the issue now. doh!
                    ๐Ÿ˜•
                    ...and I thought I had gotten peace at mind... ๐Ÿ˜ž
                      So how do you calculate it?
                        arg... I keep wanting to make quide circles... I see how difficult this is with native SketchUp now...
                          I'm not sure how you'd calculate it. I think the only dimension you know is the width of the board. the length of the miter and the length between ends will change as the angle changes due to changes in the spacing between posts and the height of the posts. And you don't know any of the angles either.
                            • Width of the board
                            • Diagonal of the board
                            Surely this should be something to work on?
                              But you don't really know the length of the diagonal of the board when the miters have been cut. And the overall length of the board is immaterial.
                              If you working in real wood, you would get an estimated length so you know the piece of wood you offer up is plenty long. You'd nail it in place and cut the ends off flush with the posts.
                                @jason_maranto said:
                                This is really easy with the native tools -- here's a short tut file: [attachment=0:3gkxsinp]<!-- ia0 -->challenge.skp<!-- ia0 -->[/attachment:3gkxsinp]
                                Best,
                                Jason.
                                How do you place the horizontal guides such that you get the fixed width of the diagonal board?
                                  Looking at it, it's just as if you skewed a 0,50m board - which is not correct.
                                  • jason_marantoJ
                                    jason_maranto
                                    This is really easy with the native tools -- here's a short tut file: challenge.skp
                                    Oh, I see why this might be a challenge -- you want a specific width to the crossboard... give me a sec.
                                    Best,
                                    Jason.
                                    • andybotA
                                      andybot
                                      Too funny Jeff. I do this all the time in AutoCAD with a circle guide, but stupid sketchup segmented circles, I really don't see any way. Thanks for the brain melt... ๐Ÿ˜†
                                        Until today I have never been too bothered about SketchUp's segmented arcs and circles - I've always found a way around it. But this... arrrrhh!!!
                                        And - I noticed if you have a circle, make a pie segment where one line snaps from centre til vertex and the other from centre to mid-segment - SketchUp will claim the segment is an Arc. But it's not! ๐Ÿ˜ฒ I was thinking that if I adjusted the segments with the Entity Info the arc would readjust the two ends to be true to it's original circle - but instead it result in two different length radius.
                                        • andybotA
                                          andybot
                                          ... thus - for best accuracy, draw it in ACAD and import into sketchup ๐Ÿ˜’
                                            Have you the files in V6 ? ๐Ÿ˜‰ (save as V6)
                                            • 16
                                            • 17
                                            • 3 / 17
