    Mini-challenge
    328 Posts 26 Posters 57.7k Views 26 Watching
    • jeff hammondJ Offline
      jeff hammond
      draw the pink board
      click pic -> bigger
      dotdotdot
      • brookefoxB Offline
        brookefox
        Gimme a model?
        ~ Brooke
          brookefox
          Perhaps I was joking, perhaps not, but what have I got to lose. I'm gettin' out my pen and paper right now.
          Something smells fishy around here.
          ~ Brooke
            jeff hammond
            it seems simple but it's actually hard to pull off in sketchup.
            just throwing it out there to see if someone comes up with something more slick than how I've been doing it.
            (edit-) as in, my current method isn't very slick.
            dotdotdot
              jeff hammond
              @brookefox said:
              Gimme a model?
              you can make up your own dimensions as they're not (entirely) important.. (it's mainly about getting the parallel lines of the pink board in there like that)
              [EDIT] oh wait, the width_of_ board dimension is critical but you can make that dimension up if you want.. you just have to choose what it is first then draw it..
              but here's a starting model anyway..
              mini__.skp
              dotdotdot
              • N Offline
                ninopiamonte
                Can you give something more details about this challenge?
                  jeff hammond
                  you mean like prizes and stuff?
                  this is a fairly common situation in framing when an X-brace is required.. often, you're able to just trace them onsite but other times you can't (other walls in the way etc..).. either way, it's nice if you just have the right dimensions in the first place..
                  another example of the same problem.. (2x4 wall frames connected by a brace)
                  so the the challenge is for you to show your technique (probably via screenshots, .skp, or video) showing the best way you can come up with to draw the brace board in order to obtain proper dimensions for it.
                  [and i'll act as the judge πŸ˜† ]
                  dotdotdot
                    Still not getting it... too early in the morning - haven't had my tea yet. 😳
                      My little try πŸ˜„
                        jeff hammond
                        My little try πŸ˜„
                        [attachment=0:259w4kne]<!-- ia0 -->Chall.jpg<!-- ia0 -->[/attachment:259w4kne]
                        in step 2, how do you know where to draw the line ? (at which height ?)
                        like i said earlier, your board has to be a predetermined width…
                        dotdotdot
                          It was made step 3 πŸ˜‰
                          But if you want better πŸ˜„
                            jeff hammond
                            @pbacot said:
                            I just draw a 2x4 and rotate it then cut with two uprights...?
                            doesn't work… (unless you're just sorta eyeing it into place.. but this isn't horseshoes πŸ˜‰ )
                            that's why this is tough
                            dotdotdot
                              It's implicit at my new version above
                              You have caltulated before the good rectangle for have the good result πŸ˜‰
                                jeff hammond
                                [ie--- the board is a set thickness.. it will always be the same.. the part you're measuring will constantly change depending on the gap and height (angle)..]
                                dotdotdot
                                • pbacotP Offline
                                  I just draw a 2x4 or whatever and rotate it then cut with two uprights...? I did that today in a trellis design.
                                    Does it has to be drawn correct in the first place?
                                    I was thinking, drawing the profile of the board in the correct size, extrude, rotate it, taper off the ends. - too many steps?
                                      jeff hammond
                                      ok.. i'll try to switch up the way i'm presenting the problem..
                                      draw this:
                                      (notice which way the 5 units are being measured.. if i measure 5 in the place you're suggesting, my board will no longer have a width of 5.. it will be too skinny)
                                      dotdotdot
                                        This is an elaborate plugin request - right?
                                        • pbacotP Offline
                                          Well if you had a true arc or circle you could find your exact intersection points. But there are no true circles in SU.
                                            jeff hammond
                                            take as many steps as needed.. but for you, once you recognize the issue, you'll probably immediate think ruby as a means of solving it.. the way i do it is with a dynamic component.. there's a brute force method to accomplish it within sketchup itself but i'm wondering if i happen to be missing a method.. no solutions given so far will accomplish it..
                                            [EDIT.. haha.. re:your post while i was typing this one πŸ˜„ ]
                                            but no.. i didn't set out for it to be.. it's a pretty cool little challenge because of how simple it seems.. hopefully a plugin doesn't jump in too soon and spoil all the fun πŸ˜‰
                                            dotdotdot
                                            • 16
                                            • 17
                                            • 1 / 17
